Question about Philips 32PT6441/37 32" TV
Phillips 32PT6441/37 32 Inch Screen / Power problem
My television will turn on, however it has a gray screen with lines running across it. After 10 seconds, it will turn off. The green light beside of the power button will flash 11 times-pause-1 time-pause- and then 1 long light and then it will start over.. Any idea what this means? Thanks!!!
    Genius:
  • 1,694 Answers
Open 10 ohm 1/4 watt resistor on RGB circuit board.....CRT
socket module....replace with 1/2 watt...................T.
Posted on Feb 18, 2008
    Problem Solver:
  • 9 Answers
Heres whats going on. You have no B+ to you video drive IC, therefore, you RGB runs at 100%, the tv turns off due to over current protect. Heres the most common fix
Check 3351 (res) on crt PCB near video ic, it will be open. Changing, if it smokes you will need to change the Video drive ic, which is a TDJ6107. As a rule, I change both when this problem comes up.
Master Tech Ace
Posted on Feb 13, 2008
  • 48 Answers
I fixed this very problem several times on this set. You must check some parts and, if bad, replace them correctly and safely. I can tell you what to look for for a small cash fee, but I don't know how this works on this site.
Posted on Jan 28, 2008
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it...
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Dec 15, 2011 | Toshiba 42H82 42" Rear Projection...
My tv has white lines that run up and down across whole screen. it has like 4 lines then a inch space then 4 lines and a 3 inch space My tv is a SAMSUNG HL R5667W
Power supply board, Look for bad capacitors they will be vented or puffed up on Top.
Encompass parts has whatever you need for this model
1-800-638-3328
Mar 02, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
32 inch jvc av-32d302
Those are called retrace lines. The electron beam has to go back to the beginning of the screen as part of its raster scan. Normally it is turned down so that it can't be seen. There is a little adjustment knob on the high-voltage flyback transformer called "screen" that will hopefully adjust this for you. If that doesn't work it is an indication that the high voltage circuit is dying.
Hop Ya Fix It.
Feb 01, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Philips 32PT6441/37 32" TV Logo
263 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
