Question about Olevia LT32HVE 32 in. LCD Television
High pitch sound from the speakers
I have this annoying high pitch sound coming from both speakers. I checked the cable hook up and all of the power sources, I even tried a DVD though the system and I still heard the buzz, after a hald hour I started to develop ear pain and a headache? Ever hear of this?
  • jack322 Mar 08, 2008
    Annoying, high-pitched sound when speakers are turned on. Ceases when speakers are turned off. Not sure how to fix this.
  • 979 Answers
Is the noise present even when there is no input?
Posted on Feb 27, 2008
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
Dec 14, 2017 | Zenith Z50P3 50 in. Plasma TV
There is a significant high pitch running through my speakers. I checked speaker wires, & plugged in power cord into a different outlet. Still no luck. Any suggestions?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 06, 2011 | Harman Kardon AVR 300 Receiver
My speakers no longer have sound, even though the green light is turned on and they are plugged in correctly
There could be several small annoyances happening here. The first thing I suggest is try hooking the speakers audio (green) cable to a different sound source, such as an MP3 player, or cd player, or a portable GPS. If any of those devices allow your speakers to produce sound, then the issue is NOT with the speakers, and you need to look at your audio drivers/settings. Make sure your audio driver is installed, and make sure your audio settings are not muted. You can call your pc manufacturer to get help in determining your driver status.
May 17, 2010 | Dell A215 Computer Speakers
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Apr 17, 2010 | Philips HTS-3555 System
High pitched noise
there may be abreak on the av board . is it doing on cable,dvd another source the front panel jacks sometimes develops breaks sound like you may need a tech look at it
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Olevia LT32HVE 32 in. LCD Television Logo
226 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
