Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printed gray looks pink
When I try to print in grayscale, the grays end up looking pinkish.  I cant find a way to access the levels of pigments that are printed to achieve "gray".  What can I do to fix this?
  • Kelsey k Jan 28, 2008
    I've already changed all of the ink and done all of the allignment prints and cleaning things that are offered in the settings of my printer.
  • Kelsey k Feb 26, 2009
    I already checked the cartridges and they are all the correct ones for my printer
You likely have installed a "Photo Cyan" or "Photo Magenta" color cartridge instead of a "Cyan" or "Magenta" cartridge (6PC vs. 6C, for example). Check to make sure each cartridge is the correct cartridge for your printer.
Posted on Feb 26, 2009
  • 3 Answers
Maybe the print heads need cleaning?
Posted on Jan 27, 2008
Lexmark Pro 905. How do you print a document in black only. I know how to make copies in black but I can't figure out how to print in black.
Go into the color control settings and pick Grayscale or B&W; if you pick grayscale be sure to test print and adjust print density so black doesn't look medium gray and the rest illegibly ephemeral.
Aug 06, 2011 | Office Equipment & Supplies
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
I have a pixma 1500 and I need to print black and white prints. I am using edible paper and edible ink. Instead of black and white I am getting pinkish gray instead of gray. I was told before that I...
Apparently, when grayscale printing is selected, some color ink is still used which is why you are getting a pinkish gray color instead of just gray. Here are instructions for solely using the black ink tank.
Print using pigment black ink only (Windows)
Instructions to print using only the pigment black ink tank only. Occasionally you may need to print using black ink only. Using grayscale alone does not provide this option and the color inks will still be used. By following this procedure you may print using only the pigment black ink tank.
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
Open the Properties / Preferences window for the printer.
For Windows 7
Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/ Me/98 (if applicable)
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click on the Main tab.
Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
Apr 23, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Using an HP LJ1320 printer. When I print my page comes out with a faint gray look to it (not white). When I duplex the gray intensifies. I thought my toner cartridge was leaking toner so I replaced the...
Your Print density could be set too high.
Try to Decrease the amount of Density through the device configuration utility.
You Must have teh HP Toolbox installed to change printer settings
Feb 15, 2011 | HP LaserJet 1320 Printer
The printer prints color only.
There is an option to make your prints come out in black and white if you go into the "properties" of the printer. Look for an option that says "grayscale". This will allow your prints to come out in shades of gray (black and white).
Hope this helps. :)
Oct 06, 2010 | HP Office Equipment & Supplies
Prints in gray want it to print black
check the properties of the printer and make sure its not checked to print grayscale.
May 02, 2010 | HP Photosmart C4150 All-In-One InkJet...
Hi, I have a Macbook running Tiger 10.4.11. I have yet to figure out a way to print in black and white from safari. HELP!
When you go to print (apple/p) and the dialog box comes up (lists printer, presets, copies, etc)
There should be a gray horizontal line across the middle of this dialog box. Note the drop down box that is on this gray line ... this is an important drop down box. When you select different items in this box, all the options underneath the gray line change.
The selection in this box is probably "Layout" by default. Change it to look at the different options, but as things change below the gray line don't get confused about which is the "main" selector drop down for changing all the options .. it's the one on the gray line ....
I'm using an HP printer, and when I select "Paper Type/Quality" in this drop down, I get an option under the gray line that says "color" -- the options in that box include the option for "Grayscale"
If I were to select Grayscale, then the printer will print only in black and white and shades of gray.
That's the easiest way to do what you want, and it will apply to any program you are printing from, since you are selecting "Grayscale" from the print dialog.
Look through all the different variables in the print dialog to become familiar with them.
If you often use one particular setting and don't want to have to go through the sometimes confusing search through the drop downs, since they change back to their defaults each time you print, then you can set a "Preset" - this will remember your settings and allow you to get to them easily ...
To do this, first select all the options the way you like them, for example you might select Grayscale under the Color option under the Print Quality section. Then, before you actually print anything, go the the top where it says "Presets" and do a "Save As" and choose a Preset name that will be meaningful to you ... like "grayscale" -
Next time you print, keep an eye on the preset - it may NOT go back to the default of "Standard." It may stay on the last-used Preset ... so keep an eye on it before hitting the print button.
Hope this helps!
For help with Public Address system feedback, and great AA speaker tapes and MP3 downloads, my website at rexark.com is a great resource!
Feb 08, 2010 | HP Photosmart C6280 Printer
Everytime I change my print to grayscale it prints in pink
Not knowing what sort of printer you have it's hard to pin-point exactly what the issue may be. Taking an educated guess I'm going to guess that you are using an inkjet of some sort. These printers will often use a combination of the cyan, magenta, and yellow inks to make black and shades of gray, and it is possible to get pink instead of gray if the cyan and and yellow are to low to provide a mix to produce gray. Try new ink cartridges to see if that makes any difference...some printers, like DesignJets use individual cartridges for each colour, and most small printers use a combination cartridget that contains cyan, magenta, and yellow ink in different reservoirs in the same tank.
If you are using a printer that doesn't require both the colour cartridge and the black cartridge in to function, try pulling out the colour cartridge and printing in grayscale. Most printer drivers are designed to recognize the fact that the printer only has the black cartridge in it and will automatically make the necessary adjustments.
Jul 27, 2009 | HP Office Equipment & Supplies
Black & white photo printing reddish-pinkish-orangey
In the Printing Preferences select to print in Grayscale.
Sep 19, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PRINTER
go to file print, then properties and select color settings or look for a gray check box that is checked for gray scale
Dec 03, 2007 | Computers & Internet
Canon PIXMA MP600 all-In-One InkJet Printer Logo
381 people viewed this question
old marine
old marine
