Question about Harman Kardon AVR 100
Harmon Kardon AVR100
My unit turns on then turns right off. and the power indicator light is red.
Can I fix this myself?
Thanks
  • Anonymous Feb 19, 2008
    Harmon Kardon AVR100 When it worked fine. Hit the power button, the stereo would click then a short pause then it click again and be ready for use. With the problem power, click pause then click off. Tried taking all the speaker wires out nothing attached and it still did the same thing.
    Problem Solver:
  • 7 Answers
Am in this field for more than 20 years n would never suggest such a solution ?if u do not know about electronics plz do not poke ur nose .the black box is called relay,it protects ur amplfier,when u push the main switch the relay enters into action.if all the sytems r ok then it energised after which all the set wrks.wat u have done is u have blocked this component n the whole protection system is off.
Posted on Oct 19, 2008
May I suggest that you read your owners manual, last pages, troubleshooting.
If your power light is red, it is a microprocessor fault caused by a probable short in the wiring (speaker, etc).
Find that problem, then hold the cd and vid2 butttons while you turn the unit on. This will reset the processor.
DO NOT bypass or circumvent the power relay. This is a bad idea.
Posted on Nov 05, 2008
I had the same problem so I came here. I saw the post by Guest and started to look into that solution. It didn't work. But it did put me on the right track so thank you. I found the problem to Be a mechanical Switch in the back left corner of the unit (looking from the front display). Here is how to fix it.
First open the unit by removing the 3 screws from both sides and the 4 from the back.
next looking from the back of the unit to your right where the power cord goes into the back there is a circuit board. on that board there is a black rectangular box that is where the problem is
If you want to confirm this carefully plug in the unit and turn on the power if the light turns red and the unit doesn't turn on turn it back off and then on again but this time tap gently on the black box the unit may turn on for a short time. If it doesn't don't worry it is still probably the problem.
Next BE VERY CARE FULL AND GENTILE, using a small knife or screw driver pry open the black box from the bottom. there is a seam about 1/8 of an inc from the bottom be care full not to separate this switch from the circuit board.
Last step once you open the box you will see a solenoid switch using tape or any thing you want lock the switch to the closed position. after that you wont have the red light problem. But remember from now on you want to turn off the MAIN POWER SWITCH above the electronic switch every time you are finished using it.
Good luck I hope this helps
Posted on May 10, 2008
Dear friend, I think your wires (speaker and connectors) are laying or touching the GROUND, I had same problem, I lift them from ground level to the wall and passed the wires through the wire covers, and problem solved.
Regards,
Minas
Posted on Feb 12, 2008
    Genius:
  • 1,067 Answers
Nope its so hard to trouble shoot and order parts take a repiar shop thats good with sterios or harmankardon repair shop with right parts ok
Posted on Jan 27, 2008
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I cant get any sound out of my Harmon Kardon AVR 100 what am I doing wrong
One can not say without some significant details. Maybe get the manuals for all involved products and see how it's supposed to be done.
Here's one...
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR100%20om.pdf
Jun 24, 2011 | Harman Kardon AVR 100
I have an Harmon Kardon AVR 85 and the power will not come on. The batteries are good in the remote, I have unplugged and plugged the unit back in, but the red light stays on and will not power up. How...
First of all, if you have just been powering up with the remote, try pushing the actual button on the unit. From owning a HK receiver, I found out that if the power switch is out, it will not turn on from the remote. Duh moment when I discovered this.
It also might be an internal fuse or circuit breaker that is shorted or tripped. If there is not an outside breaker or fuse, send this to a repair person. Sometimes there are capacitors in the power amp circuit that can hold a lot of voltage for a good length of time. You could get shocked. So, you might want to let the repairman handle this. Otherwise check for an outside breaker or fuse, and replace if needed.
You can also check Harmon Kardon's site for customer support.
Feb 19, 2011 | Harman Kardon AVR 85
What year was harmon kardon avr100 made
It was first available on Amazon in September 4, 1999.
Feb 01, 2011 | Audio Players & Recorders
I just hooked up my harmon Kardon 2.1 amp after moving and when I fired it up instead of warming up and the indicator light turning green. It turned orange and pulsed red. I could here the amp relay...
Check the speakers, make sure no starnds of wire are touching ony of the other terminals. Disconnect one speaker at a time and turn on the unit to see when and if the unit stops going in to protect mode. When it and if it doest start to stay on then you have removed the bad spkr. Unhook all of then and hook up the bad one only to verify that is whats causing ur problem...
Jun 05, 2010 | Harman Kardon SIGNATURE 2.1 Amplifier
Voltage Spike / Power Surge Harman Kardon AVR 130
In this case is pretty hard to give a diagnostic. There are plenty of possibilities. It has to be seen by a tech
Apr 05, 2008 | Harman Kardon AVR 130 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 100 Logo
828 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
