Apple iPod touch Logo
Anonymous Posted on Dec 28, 2009
I just got an i touch, weird pattern behind glass
I just got an i touch, barely used and now there is a pattern behind the sceen that looks like it has moisture in it. I did not get it wet or take it out in the cold air. Any idea what is wrong with it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
48
Points
It sounds like it got crushed, or had too much pressure applied to it. This happened to my ipod before when I left it in my backpack. Hate to say this, but it costs more to fix it then buy a new one (At least, that's what I was told). If you can still get it to work properly, thank your lucky stars. If you can't get it to work, it's busted. iPods are made pretty cheaply. Cases are the best way to go. If there is absolutely no way that it got crushed, take it to your nearest apple store, or send it to apple through the mail.
Hope it has a warrenty on it. =(
Testimonial: "Quick and appears correct"
3answers
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
1helpful
I have a maytag gas dryer mgdx500xw, with door open and light on, circuit breaker blows, with door closed it does not, if I remove the bulb, it won't blow either way. Weird?
the return neutral wire from the bulb has to have a bare spot on it touching the metallic case somewhere in the dryer,when you remove the bulb you just isolate the bare spot on the neutral wire from the hot wire
I have a Mitsubishi 52628 that has a strange pattern on the left side of the screen.
I had this strange occurance too. It appeared right after I connected the antenna wire so I changed to another style input and got the full screen shot. i did not investagate the input on the tv further as I had other connections i was able to use. I hope that helps with yours.
How do you remove the glass from the side mirror enclosure?
Hi, this mirror glass is held in with plastic tabs, in a circular pattern, on the back side of the mirror.Wearing proper gloves, simply grab the glass behind the black backing, and pull out on it, BE CAREFUL OF BROKEN GLASS. Once the glass is out, remove any wires that may be attached, by simply pulling them off of the connectors, replace the glass, and pop back in.
Reds come out yellow, and facial tones are too red
It sounds like your machine needs to be calibrated. First try turning the machine off and unplug it for about 15 seconds. When you turn it back on it will reboot its software and stabilize the image units. If this does not correct the problem you can perform a gradation adjustment by:
1 Load 11 × 17 L-size paper into the 1st drawer.
❍ Letter C, A3 L or A4 C can be loaded instead.
2 Press the [Utility] key.
3 Touch [Admin. Mode].
4 Using the keypad, type in the administrator code.
❍ Touch [Enter].
5 Touch [Gradation Adjustment].
The Gradation Adjustment screen appears.
6 Press the [Start] key.
A test pattern is printed.
7 After the test pattern is printed, a screen appears, indicating how
the test pattern must be loaded.
8 Place the printed test pattern on the original glass.
❍ Align the edges of the printed test pattern with the document scales.
9 Place into the 1st drawer 10 more sheets of blank paper of the same size as the printed test pattern page.
10 Close the original cover, or the reverse automatic document feeder if it is installed.
11 Press the [Start] key. The printed test pattern is scanned.
12 Based on the scanned image, the gradation levels are automatically adjusted.
After the gradation levels are adjusted, the Admin. Mode screen appears again.
13 Repeat steps 5 through 12 three times.
14 Touch [Exit], and then touch [Exit] in the Utility screen.
3helpful
2answers
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
1helpful
2answers
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
2helpful
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Wet rear projection sceen
You may be able to reach it through taking off the back cover and wiping the screen down. If not you will have to remove the screen assembly.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
