Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
The solution has stopped going out the hose. The hose seems to be deep inside the machine. How do I get to it to unclog it?
    President:
  • 1,673 Answers
The hose unhooks by the motor. But it could be the valve in the hose head. Maybe this picture will help:
Posted on Feb 22, 2008
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
If the hoses are plugged would vinegar work to unclog them instead of lime away?
you must try to unclogged from your machine. or blockage . 2) or test the pump-motor for defective parts inside.
go to http://www.dyson.com/support/help.asp?article=32&product=DC22-MOTORHEAD-US
and select the model exactly, and proceed with common sense for troubleshooting, and see the video.
God bless you
Jul 15, 2012 | Vacuums
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Suction not working well. how do I unclog?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Nov 27, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you hook the hose up to the sink faucet?
STOP! Stop before you do some serious damage (and possibly electrocute yourself). Admittedly, I'm not familiar with this particular machine, but I don't know of any vacuum cleaner that requires a hose to be connected to a faucet. It sounds like a recipe for disaster! If necessary, go to the Bissell website and download a User Manual.
Feb 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have kenmore progressive and it is clogs is there a way to unclog it
The easiest way we unclog this machine is to take another canister vacuum and use its' hose to put on the hose of your machine then switch it on and **** the clog out of your machine. Works great.
Dec 01, 2009 | Kenmore Vacuums
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
No suction in the hose
Take the Hose out bcack run the water hose thru it full blast to unclog it then leave it hanging to dirty all the water left inside out.
Aug 20, 2008 | Bissell 6594 PowerForce Bagless Upright...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
187 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
