Question about Maytag MAH6700AWW Neptune Front-Load Washer
My Maytage Neptune Front Loading Washing Machine
Machine started, water pumped in, then it stopped, the code "nd" started flashing which in the past meant the drain was frozen. Checked and drain is not frozen and now there's no code at all. When you start it, the door locks, but nothing happens.
    Genius:
  • 1,554 Answers
These units all use the same computer module to control it.
random failures are part of the symptom of bad solder joints on board.
loose cables to the control computer can be part of it too.
opening the top (3 scres on top back) and re-seating the connectors will take a couple of mins , the solder job can take 30 min or more.
see these links as this applies to your unit too even though the models are not the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
http://www.flickr.com/photo_zoom.gne?id=471156850&size=o
Posted on Jan 29, 2008
My washing keeps clicking locked and then unlocking. Took three times for it to start and it is making a noise I haven't heard before. We bought it 7 1/2 years ago. I take good care of it. Now the it...
Hello there and thank you for choosing fixya
Ahhh, the ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. I've seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: Rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump?
If you have a floor drain you should be able to drop the discharge hose to the floor and let gravity pull the water out so you can take the pump out and get a good look at it.
Also a word of advice to avoid wasting time. The pump is usually towards the front of the machine. ok?
Hope this is very helpful for you
Best regards Mike
Jun 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
Code on MAH9700 display is ND- clothes are sitting in water.
Some other items known to stop a Neptune pump: rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump.
Hope this helps.
Jun 03, 2011 | Maytag Neptune MAH9700 Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stopped with a load and water displayed a code of nd
When error code "nd " flashes remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining. This will fix your problem.
Thank you !!
Jul 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nd on washer
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't finish cycle, water still in tub, code nd
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune
"nd" refers to a No Drain issue .check for restriction in pump, restricted drain hose loose wire at pump, bad pump.
The pump had a suds lock. Unplug the machine for a minute. Plug it back in and run a cycle on hot to get rid of the excess soap.
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
