Question about Mitsubishi WS-55513 55" Rear Projection HDTV
HDMI compatible? Will the new HDMI DVD players work on this TV with the HDMI to DVI connector. Will the TV still convert to a 1080/p signal?
  • 395 Answers
Yes the DVD player will work on it thru HDMI to DVI connector but however the audio is not carried on DVI so you will have to have a seperate audio cables. also the 1080p signal is not supported by this set 1080i only.
Posted on Jan 31, 2008
I NEED SONY BRAVIA T32 FULL to conect to computer and camera
Hello there,
Here is the link to the full manual:
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Aug 10, 2011 | Televison & Video
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
I have a new macbook and I wanted to use it as a dvd player on my insignia tv. I bought the DVI to VGA converter cable but get no signal. What gives?
dvi-d???? dvi-d is digital, and is NOT compatible with a vga signal. vga, is an analog signal, and needs the non-digital version of dvi to work.
Mar 07, 2009 | Insignia Computers & Internet
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
DVD Upconverters???
Greetings jhays82,
Some DVD players can upconvert DVD signals to resolutions that match those of HDTVs, and send them to a compatible TV via a digital video connection. HDMI (High-Definition Media Interface) and DVI (Digital Visual Interface) both offer high-quality digital transmission of standard- and high-definition video signals. HDMI can also carry multichannel audio, and is backwards compatible with DVI (video only). So in other words, to receive the full benefit from an upconvert, you would want to hook it up with HDMI or DVI.
Thank You,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Televison & Video
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
