Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
I think I have a convergence problem but looking through solutions I have become confused Help?
I have an echo of red on my picture ( specially by the lettering) and my screen now has a strong blue tone throughout. I read some solutions for both of these problems and it seems that it is there the same part, "the convergence board". I tried to fix using the remote and I could line up all the red crosses (some would not move at all) Two different part numbers are listed below from two different websites. Which part do I need for this problem? I have a Samsung Model HCN4226W SVC Model HCN4226WX/XAA Also what is the difference in these model numbers for my TV? 1.http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx 2. http://www.samsungparts.com PART# BP94-00155A
  • dmolinari Jan 30, 2008
    Ok! Thank You, I will open my tv and look for this number inside.
    President:
  • 4,402 Answers
To tell which board you have there should be writing on the corner of the board in white.
Posted on Jan 29, 2008
Looks like its in 3d red and green
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 14, 2011 | Hitachi 43F300 43" Rear Projection...
The picture in my tv is coming up as triple there is a green picture, a red picture and a blue picture and it gives it a 3D effect, the picture curves down in the centre. the make of my tv is LG and the...
  • Screen looks 3D
69189a5.pngSOLUTION
May 11, 2011 | Samsung PCL541R 54" Rear Projection...
Bowed picture & red/blue/yellow separation
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 19, 2009 | Televison & Video
Hitachi TV, has red ghost lines outlining image on screen! Help!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
  • Screen looks 3D
Feb 18, 2009 | Sony KP-53HS30 53" Rear Projection...
Picture is distorted.. 3d like on rear projection tv.. see red, white, green colors now... help ;)
  • Screen looks 3D
0667c5f.pngSOLUTION
Feb 02, 2009 | Philips 60PP9753 60" Rear Projection...
Color distortion and arched picture
  • Screen looks 3D
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
9p6040 c102 philips magnavox rear projection tv
  • Screen looks 3D
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Red sideways hourglass
  • Screen looks 3D
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Triple picture and purple bubble on big screen
  • Screen looks 3D
Sep 25, 2007 | Sony KP-48S70 48" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
