Question about Optoma RD65 65" Rear Projection HDTV
Shading on screen
I have a Optoma RD65 DLP television. I have shading on the right side of the screen. It started small about an inch wide but is now probably 4 inches wide. You can still see the picture behind the shading, someone suggested that it possibly got bumped (I have 2 kids but neither are owning up to it, not suprising) and the mirrors are out of adjustment. Any suggestions on how to correct this?
  • 6 more comments
  • rock hill Feb 10, 2008
    I have the same problem?? What and how do you fix it??
  • adkd89 Mar 18, 2008
    Mine started out about 1 inch and is now at 2 inches. Any help would be great.
  • RCTrego Mar 30, 2008
    I have the same problem. It started after I used compressed air can for computer cleaning to clean out TV from dust because it was shutting doen on thermal.
  • kmbigbee Apr 05, 2008
    Our tv is in a cabinet, and still has the same problem. About a 2 inch shaded strip on the right side of the screen.
  • superg2k Apr 14, 2008
    I have the same issue, same TV. Mine started out at about 1 inch, now its up to about 6 inches at the top. to about 5 inches at the bottom.
  • Anonymous Apr 14, 2008
    Same problem. Sorry to say that your light engine will need replaced. (not easy to do, and will cost approx $800)
  • rpriory Jan 29, 2009
    Quite a piece of junk!  I have a 8" wide vertical band on the right side of the screen.
  • Anonymous Mar 13, 2009
    have that problem plus a short lamp life warning - ordered new lamp, prior to arrival lost the picture and sound, have replaced lamp and now have no sound and no picture at all ,flashing codes indicate need lamp replacement, installed another lamp and currently have no sound no picture and no authorized repair centers in the Maryland area that I can find.
Here's a guy from AVS forums that did a fix himself
http://www.avsforum.com/avs-vb/showthread.php?p=9267492&&#post9267492
Posted on May 02, 2008
Open the TV and push the screen back in place
Posted on Jul 09, 2008
My tv a Optoma RD65 made a popping noise, then the screen whent black.
most likely a faulty power cord not sending enough power to the TV or the projectors, for projections, bulbs for plasma, burnt out
Mar 01, 2011 | Optoma RD65 65" Rear Projection HDTV
6 inch Shadow on tv screen of a Optomatv model RD65
OK , the tech was yanking your leg . second its the light tunnel has collasped , if parts are available maybe , other wise L/E ( light engine).
Jul 08, 2010 | Optoma RD65 65" Rear Projection HDTV
Pink shading on panasonic PT44lcx65 tv
DLP image problems are usually related to the digital video board, will probably not be cheap. might even need a new light engine. good luck Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
I don't have a remote
Search with google for optoma rd65 (no hyphen) once you get the first set of results, scroll to the bottom of the page, click search within results and search replacement remote. this is just one site I found.
http://www.remotes.com/store/optoma/rd65.html
Jan 28, 2009 | Optoma RD65 65" Rear Projection HDTV
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
Optoma RD65 65" Rear Projection HDTV Logo
341 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
