Question about Samsung 793S 17" CRT Monitor
793S 17" CRT Monitor Problem
The led power blinking and there is a sound of contac relay on then off
and no high tension ,nothing on the screen
  • 4 Answers
Have X2gen LCD Monitor with the same type of problem.
Take apart the LCD screen and reseat all ribbon cables. Make sure they are connecting right. I found a black wire on one ribbon cable that was not seated in the connector correctly.
RESEAT ALL CONNECTORS carefully to avoid breakage.
Look for discoloration on all connectors to see if they was an overvoltage to a short causing the screen problems. If you see discoloration you know you have the connector they cause your screen problem.
Posted on Jan 28, 2008
Samsung 793S (Black) 17
On these older CRT monitors when you have that type of problem it indicated that the high voltage power supply is not putting out the right voltage to charge the picture tube. As the power supply gets weaker the time to show a picture will take longer and longer. It is not worth repairing the unit because parts will run much more than a replacement monitor.
Jul 19, 2012 | Samsung 793S 17" CRT Monitor
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Screeen went blank after changing resolution and hz appeared
refresh set to high boot safe mode change settings.
this has worked for me and XP.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Samsung793s led blinking no disply
the vga card is not connected properly i think in cpu .. just reconnect it... and then have a try..... it should work...
Feb 13, 2008 | Samsung 793S 17" CRT Monitor
Check relay in power section for fault.To degaus the monitor.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Jan 10, 2008 | Samsung 793S 17" CRT Monitor
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
Problem in monitor 793s (no high tension,power led is belinking,hearing a sound like contact relay (on then off)
Time for a replacement, CRT monitors are not in the realm of repair, just replacing. You could get a good deal on a used one as these monitors are becoming obselete!
Oct 25, 2007 | Samsung 793S 17" CRT Monitor
Samsung 793S 17" CRT Monitor Logo
110 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
