Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer will not work
Moved to new home had to replace outlet to 3 prong. Plugged dryer in and panel says PF . cannot get dryer to work.
  • bellcleo Jan 28, 2008
    fixed problem changed dryer plug to four prong and vice versus and it worked guess maybe dryer was not grounded, cause it did shock me when i touched door. but works great now
  • 770 Answers
PF= Power failure hit the cancel button and it should clear then you will be able to select a cycle. Let me know
Posted on Jan 28, 2008
  • Gary Davd
    Gary Davd Jan 28, 2008
    you will still get a PF anytime the power is removed from the machine 3 or 4 prong it wont matter and just an FYI
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
I just plugged in the dryer it has a "PF" message and won't do anything, unplugging dosen't change anything....
Pf is power factor. It is showing you there was an interuption of power. Some models you have to wait at least 3 minutes before you can press stop / pause / cancel to clear the PF. If you still keep getting PF go to the main CB panel and turn off the Dryer CB by physically pushing to breaker to the OFF position to reset the breaker then back to on. You will have to wait again before you can clear the PF. If after resetting the breaker you still get the PF in the display you may have to find out what power you actually have at the outlet. 115V or 230V. Other factors come into play also like 3 or 4 prong connections vs the previous connection. They do make a difference and if the power cord was installed incorrectly the PF will never clear until the cord is connected correctly.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Dryers
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Electric Dryer
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
Jun 09, 2007 | LG DLE2514 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
263 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
