Question about iLO (2 GB) MP3 Player
Speaker and headphones
Hi i have an mp3/4 player with a built in speaker, when i plug in headphones the music still comes out of the speaker, how do i stop this?
  • 8,596 Answers
Go to the settings menu and change the audio output to headphone only.
Posted on Mar 19, 2008
6ya staff
SOURCE:
Rx v2095 has problems with headphones.
All speaker / headphone combos should have a stereo switched headphone socket.
It could be that the spring-steel switch contacts in the socket are not opening for some reason - jammed by nearby stray wiring etc, or a possible short on the board, say between the solder pads at the headphone socket.
When phones are out, switch contact(s) are closed, completing circuit from amp to speakers or bigger power amp section to drive your wall-shakers.
When headphones are in, the speakers are disconnected and the audio is fed via the contacts to the phone jack-plug's tip and ring, instead.
Short story - Isolate power, remove shell, inspect and test.
Jun 12, 2018 | Yamaha Audio Players & Recorders
Headphone pluged in does not cut off speaker in toshiba laptop
Headphone socket is possibly faulty or you are plugged into the mic socket or there is a separate volume control to drive the speakers or the driver is not installed correctly.
Dec 05, 2013 | Computers & Internet
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Plug in connection problem for headphone or speakers
It can be because the connector on a mp3-player, or in this case the ipod touch, does not deliver enough power in Watt's to bring the music over to the larger headphones or speaker(s).
With kind regards,
Jeffrey
Feb 16, 2010 | Apple iPod touch
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
Aug 26, 2009 | Emerson Audio Players & Recorders
Ipod touch music wont play, built in speaker works fine
Restart your ipod by holding the home and power button at the same time, this will restart it and should fix it.
Aug 12, 2009 | Apple iPod touch
Play music from Iphone through car speaker system
If you car has a tape player then you can get one of those tape adapters and plug it into the headphones part on your iphone, then it will play through your speakers.. or, if you want to spend some money, you can take your car in and have them install the ipod hook-up.
Jun 10, 2009 | Apple iPhone Smartphone
PLEASE HELP
Posting solution to mark this as solved (even though poster already found solution):
Go into Settings menu, select Audio, and speaker output settings. The best is Auto, which will use the built in speaker only if headphones are not plugged in.
Dec 28, 2008 | Sears GC-1020 MP3 Player
iLO (2 GB) MP3 Player Logo
49 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
