well ur asking a lot here. 3004 arent that easy. sony is making sure people like me.. or us and my friends cant use the handy software provided by coders and hackers[thank them] well from my expertise i was lucky in that the person who first modded my psp 1001 had to turn my psp phat battery into a pandoras battery. His slim psp was already modded with a method he claimed and showed me that he cut one corner of a chip in the battery case which let him run the update software to mod it.. so with his software on his slimn psp and a computer program that installs pandora files threw usb connection he made my battery into a pandoras which i still have.
So know i can use it to mod psps!!!!!! and i have software that can turn phat psp batterys into pandoras no problem. i just put that batterty in mine phat psp 1001 and run the program pandora installer providedby ppdv1.0 and usedbattery options and hit pandorize battery. i tryed using a slim battery on my phat and that damaged the battery and had to buy my friend a new one..
So what im trying to get to is if you can get a pandoras battery then i can help you,.
my friend has a Slim psp 2001 and i put the same modded software and the same process with my phat and it worked! so as long as you get a pandoras battery then you can run the software!!!
http://forums.afterdawn.com/thread_view.cfm/688507 this site showed me how to mod a psp with a pandoras batterty i already had. its worked on every psp i have installed the software[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[warning WHEN INTSALLING MODDED SOFTWARE OR ANY UPDATE SOFTWARE FROM SONY YOU MUST HAVE YOUR PSP PLUGED IN AND A FULL BATTERY IF YOU DONT THE PSP MAY DIE AND MAY HAVE NO BRIAN{BRICKED} YOUVE BEEN WARNED}}}}}}}}}}}}}}}} but also just start the update program
ok so i did this 1. got "net framework version 2.0" and run it! find it by using google! 2. I then installed the psp pandora deluxe version 1.0 like stated in the website 2. find the Officail firmwares OFW 1.50 OFW and 4.01 OFW.. there are plenty of good sites just google each firmware.
then start psp pamdora deluxe and make sure ur psp is connected threw usb connection and make sure you know the drive name of the psp and select the it and then go to 1.50 and chose the eboot file and then 4.01 eboot file and then check them and then check 1.50 noonz downgrader and the despertar cemtrenio v6 [4.01 mm33 2] and then set dcv6 to the left button and the others as you plz and then check format memory stick and then hit other options and check add 4.01 m33 1.50 addon and then check suppot tolls for pandora and then support for xmb and the chose to run and hit yes and wait and now you have a magic stick which now needs a pandoras battery like mine to use
so you need to find out how to make a slim battery into a pandoras batterty without help from a phat battery. try looking up ways to make a pandoras batterty using a program that runs while ur psp is in usb connection and then the program asks for what drive your psp is and you selct it and then run it accordling .. sorry so much info
