Sony VAIO Notebook Logo
Anonymous Posted on Dec 27, 2009
My laptop wont connect to any wireless connection at all anymore, but I can plug it in to the ethernet and it works. the wireless switch is turned on and when i try to connect to any connection and it says "connected with limited access". could something be broken?
  • Anonymous Dec 28, 2009
    i dont know what a wire less card is..
    i know that my wireless access is turned on.
    i went to device manager and there was nothing that said wireless card, so im lost.
    thankyou
  • Anonymous Jan 04, 2010
    i tried updating the driver, and now it allows me to connect.
    thankyou very much
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785102
Points
9440
Hello.
For your wireless card problem, be certain that your wireless access is turned on. Often there is a switch (location depending on the model) to to turn wireless off and on.
Then, if still a problem, I'd suggest to go to Device Manager. Right-click your wireless network card and select Update to update the driver.
If still a problem, go back to Device Manager. This time delete the wireless network card, restart your computer and see if the problem resolved.
If still a problem, replace your wireless card.
Hope this helps.
    Hello.
    Look for "Intel Pro" or "LinkSys" under Network Adapters.
    If you can't find, please let me know which operating system (Windows XP, Vista, etc.) you have.
Nec lsptop
Will it connect using a Ethernet Cable?
2helpful
3answers
Router working but as soon has i secure it with a WEP key my wireless wont work anymore ???
You may need to edit the settings in the connecting computer, it may be using old specs and being rejected....without prompt, on some OS.
Wont connect to internet
First, you might want to try plugging an Ethernet cable directly into the side of the laptop to make sure a direct connection works. If that works, ensure that your wireless switch is turned on (it's usually on the side of the laptop.) Other problems could be related to your router, or your computer's wireless card. If none of the solutions above work, try resetting your router by first unplugging the power, and then the cables, and then the modem's power and coax cable. Wait a few minutes, and plug it all back in. If that doesn't work, try updating your operating system.
I just bought a dell laptop and the house hold has two desktops connected to ethernet cables to a dsl modem. the lap top we had connected wireless and now it wont connect unless we connect it to ethernet...
Turn on the wireless switch ON in the laptop if it has one. Check to make sure the wireless adapter appears in the Device Manager. Then check the wireless network connections on you computer - it should pick-up all surrounding wireless SSID's. Locate yours and enter the security keys for your modem when prompted. Make sure it is the correct number to get a connection. Also, check your modem settings from one of the desktop computers - there should be a web page for it by using your Internet browser, to verify that its' wireless transmitter is on.
1helpful
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Laptop wont connect to the internet.this web page cannot be displ
If you are connecting to a wireless router make sure that your internal wireless is turned on it is usually visible on the laptop and the switch may be on a bar above the keyboard or possibly on the side of the laptop there should also be an icon in the system tray by where the time is shown that shows a pc with little waves coming off of it if it has a red x on it then the wireless is not turned on. If you are connecting using an ethernet cable make sure there are link lights (amber and green) lit up where the cable plugs into the laptop.
2answers
Wireless switch on my pc is on but cant connect Work with ethernet cable plugged in.Are there any settings?
Things to try:
1. Plug in the ethernet cable then restart the laptop.
2. Right click on your local area connection and make sure its enabled
3. Make sure your wireless adapter is disabled.
4. Check if you need a static ip address on your work network. and if so have them assign you an ip address for your laptop.
5 Test your computers ethernet port on another wired network to make sure that it is good.
6. Get a usb to ethernet adapter for your laptop if your ethernet port is bad on your laptop.
Laptop will not connect to the internet anymore.
are you using wifi connection, I mean wireless connection or you're hooking up to a LAN network or through a modem connection?  If all this connection wouldn't worked out anymore, try reinstalling your Operating System!
1helpful
Wireless Switch on TravelMate 2430
Look on you laptop for a physical wireless off/on switch. Also, vrify that the drivers are installed correctly.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
