Question about Frigidaire GLTF2940ES Front Load Washer
Does not do fast spin
I also have the smelly, black gasket problem. I am so very disappointed in this machine - I wanted one of these so bad and it does not live up to my expectations. Now, less than 2 years old, it refuses to do the fast spin after the wash cycle and after the rinse cycle. At the end of every load, I have to run the spin cycle. An appliance repair person watched the spin only setting as it worked fine, told me I needed to not mix types of fabrics, charged me 78 bucks and left. Now today I'm getting madder and madder with each carefully sorted load! He'll be back on his dime. But it is so annoying to have to use the extra step, extra time, extra power. What a poorly designed machine. I will never buy another one (so glad I didn't get the dryer) and will make sure any one I know looking to buy an appliance will not buy a Frigidaire.
  • dorcaslb Jan 30, 2008
    I'm still waiting to hear back from my lazy repair guy. Funny how quick he was getting here when I had to pay. I don't know if water is draining properly. Usually my loads are all large loads - I'm too conservative to run it with only small loads. It will not do the fast spin on any cycle and it was touch and go on the spin only cycle. Thanks for your help. Great and quick response time.
    President:
  • 1,314 Answers
Ok that's not true its one of the best machines on the market it just has a problem first clean the gasket with bleach the appliance repair person didn't know what he was talking about im a tech and we will get it fixed ok its a a good machine i have one my self no problems for ten years now they have a new door gasket now with holes in it to drain the excess water out and prevent the black mold problem he should have replaced it just to lazy to do his job and mixing loads ain't got nothing to do with it now it wont spin real small loads properly because the tacho generator cant sense the balance but the normal loads spin fine is the washer draining all the way before spin or is water still left in the washer before spin it may take a few conversations for us to get it fixed but we will. leave the door ajar after washing to pre vent the mold
Posted on Jan 27, 2008
  • robert samples Jan 30, 2008
    never pay till the repair is done if you want to check the pump yourself i can post the instructions that's what we do here fix things on line and don't wash small loads its just if the load is too small the washer wont spin it let me know if you want to deal with it we just got through fixing a wall oven that the repair guy had left just sitting in their kitchen since dec 21 after charging them 200.00 if you want to know if its draining properly start the washer empty fill it then turn it to drain spin pull the drain hose up to the top of the stand pipe and see if its comming out strong or slow and let me know
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
SMELLY washing machine
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash
Click helped if really helped.
Apr 09, 2013 | Whirlpool Washing Machines
Smelly gasket even tho i wipe dry and leave door open
try using Baking Powder to neutralise the odor. Maytag had a similar problem once. their gasket(door boot) was gray in color and reacted with some kind of bacteria then they change it to a black rubber compound and the problem went away.
Feb 08, 2011 | Samsung WF203ANW Front Load Washer
He tub will not spin
If you hear the motor running, then possibly the brake is not releasing.
These models have brake issues, typically which start with a screech when the spin stops, and often wet and/or smelly washer issues due to poor spin speed.
Most likely either part of the brake release mechanism is jamme, the thrust bearing is bad, or the reversing switch.
applianceguru.com/forum2/27602.html
Oct 21, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
Im trying to sell a Kenmore 117 - 959 but I can't get it to move. There is power to the work light, but Im stuck. Help!
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Jul 10, 2009 | Kenmore 11101 Mechanical Sewing Machine
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Why is my 1994 Chevy S10 Blazer lugging? motor shakes and lugs.
Could be vacuum leak or bad ignition wire(s).
I had a similar problem on my "93 Ford probe. The engine idled pretty rough with shakes, Turned out to be a head gasket leaking engine coolant into the cylinder during low rpm's. At fast rpm's it was fine becuase the internal cylinder pressure was greater than the hot coolant pressure & would prevent the coolant from leaking in.
A friend has the same problem with his "94 Blazer 4.3 L, throttle body injection, manual tranny. He hasn't fixed it yet, It started a few weeks ago & is getting worse. His gets a fast idle with hiccups which causes the engine shake. He already checked the EGR valve. He also has a severe exhaust problem, Not oilly but very gray & terrible smelly, but only when the fast idle problem happens. THis fast idle hiccup problem starts when the engine is warmed up.
Nov 19, 2008 | 1994 Chevrolet S-10 Blazer
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
150 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
