Question about Pioneer XVDV830/SDV830 DVD AUDIO HTP System
Do I need an amp?
We bought a DVD/CD tuner xvdv830....with about 5 speakers and sub I need anything to complete this system. We bought at all boxed up, NEW...but my husband says you have to have an amp too.
I said, that can't be true, why would anyone sell something that did not have all the things in the unit (box) to make it work?
Another friend of ours said it IS complete...the amp is in the tuner.
Question: who is correct.
(My husband WON"T put it together because he thinks he is right)
  • maturino Jan 27, 2008
    hmm...well would you believe I don't see any power cord?
    Cant find the's that the pits!
  • 171 Answers
Typically no. The device should plug into the wall, and amplify the signal by itself. It should have one or more input RCA jacks in the back for various external devices like VCRs, CD Players or your TV box, and it should have several output ports that the speaker wires and sub woofer plug in to. You shouldn't have to worry about the signal strength or amplifying it.
Just so long as you use the speakers that were designed for the unit. If you decided to use third party speakers with a higher impedance, then you would need an amp.
Have either of you looked at the quick setup instructions in the manual? It would have basic instructions on setting up a simple home theature, and if an amp is necessary, it would be indicated there.
Posted on Jan 27, 2008
The left channel on my Nakamichi SoundSpace 8 has suddenly started
  • Complete home theater system with top-loading DVD/CD player, surround sound processor with AM/FM tuner, and center channel amplifier
  • Includes 5 satellite speakers (2-way, 3-drivers each) and dual active subwoofers with 6.3-inch woofers in bandpass enclosures
  • Supports DVD, CD, CD-R/RW, and MP3-CD formats; processor integrates DTS, Dolby Digital, Pro Logic II, and synthetic surround effects
  • Built-in sub woofer amplifiers separately power left- and right-channel satellites to minimize interference and crosstalk
  • Satellites measure 3.1 x 7.2 x 3.9 inches (W x H x D) each; subs measure 8.9 x 20 x 9.6 inches; 2-year warranty
Jul 22, 2012 | Nakamichi SoundSpace 8 System
Subwoofer is not working
Check the speaker of the Sub-Woofer. It is a common fault for sub-woffers that its lead wire will get loose contacted from its cone paper. You can repair this with caution. The lead wire can be bought from most oof the electronic spare part shops at your twon.
Feb 08, 2012 | Boston Acoustics Audio Players & Recorders
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
if you dont have a crossover you will not get the best performance out of your sub. you need to seperate the frequencies and send only the lows to the sub woffers.
Aug 25, 2009 | Car Audio & Video
No sub woffer when playing cds works fine with aux and with tuner
You have the amp turn hooked up to the power antenna lead. It needs to be hooked up to the Blue with white strip not solid blue.
Jun 01, 2009 | Car Audio & Video
AIWA TS W35U manual >speaker,subwoofer hookup
Apr 19, 2009 | Aiwa Audio Players & Recorders
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Can listen to tuner but not mp3 or cd/ dvd
Make sure you are not using the power antenna lead to trigger the amp for your mid/highs, I just had this issue with the oem amp in my truck. When I chose any other source other than radio everything would die except bass. I used the ant lead for the amp for my door speakers and the amp trigger for my sub amp.
Jul 10, 2008 | Kenwood KVT-617DVD Car DVD Player
Sub Woffer System
Could be Faulty RCA wires (they bring the sound from the radio to the amp) or a bad ground (the larger black wire coming out of the amp) This is under warrranty and you should not have to worry about it... bring it back, they make fix..
May 14, 2008 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
I need help with a system that I just bought.
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
Mar 12, 2008 | Audio Players & Recorders
97 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
