Try removing the battery entirely, and see if it will power up with just the power cable. If so, it means that your battery is causing the problem. If not, it's possible the battery is good, but the power cable has gone bad. Usually there is a "brick" in the center of the cable, make sure it is fully plugged into and connected to the cable that leads to the wall socket. In many cases that brick has a green light on it - does your's have the light and if so, is it lit up when it's plugged in?
