Question about Nintendo Wii Console
Wii Hello Last week after lighting my wii stop working. I open the wii and found that Q10 on the board was burned.! Could you please help me found this component. [email protected] Oren
    President:
  • 4,402 Answers
This is what i get
go here
Posted on Jan 28, 2008
6ya staff
SOURCE:
When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the synchronization is complete
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the syncronization is complete
click here to download repair guide if u need
Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
Hello, I need to replace my furnace control board #HH84AA015. I found the replacement part fairly quickly. Also found a bad transformer,#HTO1BC115 (primary winding indicates 'open' with ohm meter,...
Hello,The transformer (breaks) if the secondary is shorted for any reason.Also a power surge to the house/building will kill it (lighting strike/car hitting telephone pole).It might cause damage to the board.It is cheaper to try a new transformer BUT add a inline 3 amp fuse in the secondary so that will be the last transformer you have to replace(just fuses)if the short is hard to find.Power up the old board & see if it works,unless there is obvious damage.The plug sometimes comes with a new board because there is a wiring change to install it(on some) replacement boards.
Oct 07, 2010 | Heating & Cooling
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
The batteries went in my wii remote so i replaced them but now cant get the remote to work,,i"ve tried everything i could think of so now asking for your help,can you help please??
You may need to sync up your remotes to your console again.
If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console. Make sure to secure the wrist strap, and have fun!
Nov 24, 2009 | Nintendo Wii Console
Wii fit board won't work
Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
The exact procedure is:
• Even if the battery level is strong, try the following:
Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
Try these steps!
1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
Hope it helped.
Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
We used our wii fit on another wii system. After
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
Hope it helped.
Nov 22, 2009 | Nintendo Wii Fit for Wii
Wii Fit - Hoola Hoop
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Feb 04, 2009 | Nintendo Wii Fit for Wii
Wii fit
I have found that every so often, especially while stepping on the board, the Wii Fit would get disconnected. I did a little research and found some interesting clues to why it might be happening. I had a theory. Since the batteries are at the bottom of the board I thought the vibration of stepping plus the pull of gravity might be loosening the battery connections enough for the board to lose power temporarily. To test my theory I made a shim out of cardboard from a cereal box to hold the batteries firmly in place. This seemed to have done the trick since I have not had the problem since. I created a template you can get from my site http://www.everythingtech.net/2009/03/wii-fit-board-connectivity-fix/
Aug 20, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
