Question about Canon PowerShot A300 Digital Camera
Date and time will not stay set
Have checked all the batteries and replaced them. But the date and time will not stay set.
Everytime is turned off and back on has to be reset.
Can anyone help?
  • 2 more comments
  • gscheid Jan 27, 2008
    Would appreciate any help and thanks
  • gscheid Jan 28, 2008
    Yes all the batteries have been replaced with new ones including the CR2016
    The button batterey is installed correctly.
    Very interesting.
    No other thoughts?
  • gscheid Jan 29, 2008
    Batterey has been checked and rechecked and from what I can tell is installed correctly.
    Guess eveyone is running out of ideas?
    Any wild guesses?
    Thanks again
  • Canon Master
  • 4,738 Answers
Have you changed the CR2016 clock battery? See the picture and sentence at the bottom of the following webpage:
It's a common battery, available just about anyplace that sells batteries.
Posted on Jan 28, 2008
  • 1 more comment
  • CameraR
    CameraR Jan 28, 2008
    Hmm, that should have fixed it? A common error in installation of button batteries is accidentally installing them upside down. If this occurs, a diode will prevent current to flow, and the camera would act like no battery was installed. As a quick check, might want to make sure that the button battery is installed correctly in regards to polarity. If it is installed correctly, then am not sure what else could be the problem?
  • CameraR
    CameraR Jan 29, 2008
    I'm sorry, can't think of anything else except the battery. Might want to look in the thin battery slot to see if there's any obvious problems with the battery connectors.
  • CameraR
    Here's one more guess. If you have a voltmeter, might check the replacement battery to see if it's actually providing 3 volts.
Everytime I turn on my computer, I have to do F1 and reset the time and date. How do I replace the battery? It has gotten so bad, sometimes I have to press and hold start button, turns off and restart it
Hi philco1977,
Good day. The BIOS prompts you to press F1 key and reset the time and date in your system. This is caused by a CMOS battery that needs to be replaced in your motherboard which is unable to save the time and settings in your computer. In order to replace the CMOS battery, you must open your computer and in the motherboard you may see a coin cell battery. You can take it out using you hand or you may use a flat screw driver or a knife. Make it sure that when you do the replacement the computer must be turned off. Once you are done with the replacement you may have to go again to the BIOS and reset the settings again including the time and date and it will never prompt you anymore to reset you time and date settings.
Apr 22, 2011 | Computers & Internet
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Keep having to put in the date
Hello friend,
you can try to reset factory the camera and configure it from the beginning. if this doesn't fix the issue that means that the internal ROM (memory) is broken and doesn't save settings and you may contact the reseller if it's still under warranty.
Best Regards,
Oct 30, 2009 | Canon PowerShot A710 IS Digital Camera
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Time & date reset
Very often the date/time is maintained by a very small watch type battery built into the main board - there is no opportunity to replace this.
Dec 29, 2007 | SVP DC-12D Digital Camera
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Canon PowerShot A300 Digital Camera Logo
294 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
