Question about GE JBP65 Electric Kitchen Range
Broiler Sticks on
Sometimes during oven use the broiler will come on and stay on. Nothing will shut it off. Nothing has an effect on it other that hitting the breaker. This doesn't happen all the time but when it does you have to kill the breaker. There are no indicators lights at all, only a glowing broiler element. All the other elements will come on and go off normally when this is occurring. The breaker has to be off long enough for everything to cool down to room temp. Then things go back to normal. Can't seem to find a schematic anywhere to figure this out.
  • honedsteel Feb 28, 2009
    I evidently have multiple problems. I replaced the control board and it seems to have fixed the broiler problem but now the bottom element won't turn off when the oven reaches the temp the knob is set at. This happens 10% of the time. Even if I turn the control to the off position it still radiates. Almost sounds like the same problem only with the other relay sticking. Could it be a temp sensor or possibly a faulty control board. I did get a reconditioned one from Sears. Saved me 100 bucks but now maybe not.
  • 5,911 Answers
I would suspect that your broil relay on your Electronic Oven Control board is occasionally sticking. This can be a potential fire hazard if gone unchecked. Especially if this occurs randomly as you have mentioned. I would not feel safe about leaving your range plugged in while not at home, or while asleep. Most major appliances come equipped with schematic drawings and wiring diagrams as part of a tech sheet. One should be located either on the back of the range, or inside the console. The board, however is not normally a serviceable item and will probably have to be replaced. Just a heads up, the part number is 255451 and costs about $200. I hope you find this information helpful. Good luck to you and post back with any comments, questions, or concerns.
Posted on Jan 28, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 28, 2009
    The oven temperature sensor (or oven probe) you mention, if defective, would affect the operation of BOTH oven features. This would usually cause long preheat times, an oven that never reaches the proper operating temperature, or an oven that can't maintain the proper temperature. More than likely your suspicions are correct and you have another Electronic Oven Control (EOC) board with a problem. You may try cleaning the board contacts with a pencil eraser and alcohol. It may sound unusual but this is what you do:
    1. Unplug the stove.
    2. Remove the operator console back panel.
    3. Disconnect the terminal connectors from the EOC and remove the board for better access to the contacts.
    4. Take a pencil eraser and clean each board contact where the wire terminal plugs in. The eraser is abrasive enough the remove any oxidation or corrosion, but will not damage the board.
    5. The rubber eraser can leave a residue, however, so use alcohol with a cotton swab to clean.
    6. Reconnect the EOC and all wire connectors.
    NOTE: Double check the tightness of each wire lug. If the lug fits loose on the terminal, take a pair of needle-nose pliers and lightly crimp the connector, so it fits tight.
    You may have a simple matter of poor connectivity. Try this option first to see if you can save yourself the cost of purchasing a new EOC. If the problem fails to go away, you may have to purchase a new EOC. The cheapest web source I could find a NEW board for you was repairclinic.com for $192. Let's hope you don't have to purchase a new one.
    If you have questions, please let me know. I hope you find this helpful.
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Top broiler element works sometimes but not often
Sounds like an iffy clock control. You could try replacing it, but it ain't cheap.
May 21, 2010 | Whirlpool RF364 Electric Kitchen Range
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JBP65 Electric Kitchen Range Logo
134 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
