Question about Philips Magnavox 27MS343S 27" TV
Screen oversize picture
Information lost because picture is too large
  • Brian Sullivan May 11, 2010
    Does this happen on all sources (DVD, cable, VCR)?
  • 1,139 Answers
Hello sidley,
The problem you described might be "blooming" This happens due to poor HV (High Voltage) regulation. The problem might be with the High Voltage Transformer and or the Horizontal Output Transistor.
The problem might also be related to the associated circuitry of the two components.
I hope this helps
Thank you,
Posted on Jan 28, 2008
Can we take a large suitcase as well as hand luggage on domestic flights within Australia with Virgin Airlines?
The following is in regards to oversized luggage which you will pay an extra fee for. It is NOT a reference to checked baggage which is NOT oversized.
Checked baggage cannot exceed 80 linear inches and any bag weighing more than 100lbs/45kg will not be accepted for check in at the airport.
May 09, 2017 | Luggage & Travel
Downloaded pictures from my iPhone to my computer are in an oversized format that must be resized to be viewed, then saved. What is wrong?
Photos taken in very high resolution are very large physically. Thus, when viewing them, especially with a default photo viewer, they are often too large and must be resized to view. If you check the viewer settings, there may be an option for "shrink to fit" and "enlarge to fit" that allows smaller and larger pictures to be viewed full screen without manually resizing and resaving each one. If the viewer you have doesn't have this feature, search sites like DOWNLOAD.COM to find one that does. There are many out there and many of them are free.
Oct 04, 2015 | Cameras
I got a 1983 xr80. What are the piston/cylinder clearance specs.. stock? And how much can I hone/bore out?
most piston /ring kits come in .010" , .020",.030",.040" oversize
most engine re-conditioners use cnc borers set to an over size and bore to that
after honing to get the correct cross hatch pattern in the bore , that is it
the ring gap is what is important and it should be around .003" per ever 1" of bore
so for a 3" bore the gap should be around .010"
experience has proved that if the cylinder is bored to say .020" oversize then when the gap for .020" oversize rings is checked ,it generally comes in around .015 and even as large as .020"
max specs for ring gaps is .025" which is for a worn cylinder
just honing a bore is a waste of effort as bores wear in a taper ( larger at the top than the bottom and this taper increases the wear of the new rings and can lead to broken rings
the ridge at the top of the bore has to be removed to allow the piston to come out easily and to prevent piston failure when the new rings are fitted
have a talk with engine reconditioning shops and then make an informed decision
remember that if the cylinder can be separated from the crankcase , you can buy standard or oversize piston/ring/cylinder sets as assemblies so there is no need to bore out or hone.
Sep 03, 2015 | Motorcycles
Lost microsoft outlook 2003
What is the error message you are getting? Or you are just not able to open the Outlook application? Provide more information so that I can understand the cause of the issue. To add more I would like one more thing you should also check the size of the PST file as sometimes Outlook becomes inaccessible due to the oversized pst file. Check the following post :
Dec 02, 2012 | Microsoft Computers & Internet
Picture is too large for screen
HelloPicture adjustments should be done to get correct picture size. All these adjustments are given on page [16] of the user manual. It is not possible to include all illustrations here by this window. According to the manual, just do factory default. Proceedings are there. OK.
Dec 19, 2011 | Dynex DX-L19-10A LCD TV
Samsung UE40B7020W set up.Not happy with picture in standard definition. Great picture with Blu-ray but poor in standard.
because the image is magnifed so much on large screens, standard definition video may look blocky or jaggy ... an "up converting" DVD player calculates and fills in the needed information and makes a far smoother result .. standard resolution was never intended for large screens but "up converting" does a nice job of fixing that ..
Dec 07, 2009 | Cell Phones
Screen is size is to large can't find minimize box
Not enough information. What window are you talking about? Press the "windows" button and the "M" key to minimize everything. Right mouse click on the center of the screen and select "properties". You can then change your resolution so that things fit properly.
Jan 05, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Do not know how to change settings
My screen information is too large to read. When I try to change settings, I am unable to see the "OK" or "APPLY" buttons at the bottom of the page. How can I adjust my screen so that I am make changes.
Dec 30, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Oversize Message
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
