Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Fridge side by side refrigerator is not cooling and compressor in the back is very hot?
  • 2 more comments
  • Anonymous Feb 22, 2008
    Compressor turns on and runs for about a minute and then I hear a click and it turns off. It feels warm. Is the thermal switch plugged into the compressor.
  • glasers11 Feb 22, 2008
    I have the same problem, the compressor turns on for about a minute and then you hear a click and it shuts off. Does the thermal switch plug into the compressor or is it the little black thing that sits on the side of it
  • Anonymous Aug 16, 2008
    my refrigerator cools just fine--the compressor stays very hot to the touch --is this a fire hazzard or normal----thank you
  • Ian Fair May 11, 2010
    How old is the frige?
    If new, did it cool initially and then quit?
    If the metal coils are exposed in the back, do they feel warm?
    Is the compressor making more noise than you think a frig should?
    President:
  • Whirlpool Master
  • 2,651 Answers
Overload relay is plugged into compressor , nevermind the black box its a run capaictor(rarly goes bad) remve overload relay and shake it, shloudnt make any noise
Posted on Feb 24, 2008
Its running cool, But not cold, and will not freeze, the fan is running, the compressor is very hot,, I thought it might be that defrost bar, in the evaporator was not working, which would mean its...
Not cooling compressor running... Verify fan by compressor is running. Verify doors are sealing.
Are Coils are hot in the back by compressor? Clean exterior coils.
Jul 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
Dec 12, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My refrigerator is humming rather than running as normal. The water dispenser is not working. Both problems showed up at the same time. Any ideas?
There are different types of humming. Pull the fridge out to allow access to the back where the compressor is. Look for a thin pipe on the compressor and feel if it is hot or cool(hot means you cant hold it for pong) If pipe is cool, your compressor is faulty and this needs to be replaced. At this stage the compressor itself should be excessively hot. This could explain the water dispenser not being cold. If it is actually not working, one needs to check the solenoid valves at the back: or possibly the water filter is blocked: or solenoid limit is faulty..
Oct 23, 2009 | Frigidaire GLRS234ZA Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
KitchenAid Side by Side Refrigerator
hi thanks for the question is the compressor running . pull away from the wall remove back cover and check the compressor if its hot and running with no cooling you have a failed compressor thanks the appliance doc
Sep 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Maytag side by side
Sounds like a compressor problem. Unplug it and check the condenser for cleanliness. Clean if you see any dust build-up. Condenser may be located in back behind a removable panel. be sure to reinstall the panel when you are done. If the compressor is hot allow it to cool off and plug the refrigerator back in. If you get a hum and click from the compressor call for a service tech.
May 22, 2008 | Hotpoint HSS25GFP Side by Side...
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
117 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
