Question about Protron PLTV-32 Television
MOTH A moth flew across my LCD screen, and now there is brown mark down the center of what used to be a beautiful picture. My screen cleaner did a wonderful job on every other mark but this one. Any suggestions on how to get it off? THANKS
  • Anonymous Feb 13, 2008
    I Have the same ugly mark that wanders down the middle of the screen.  The
    mark is not on the surface of the screen.  Don't know if a moth caused it.  All
    of a sudden it was there.  At first a small mark and now it continues to grow.
    The mark starts center screen  at top and is quite severe.  As it proceeds
    down the screen it broadens and is slightly less pronounced and veers to the
    right and then back to the left, fading slightly as it progresses downward to
    within an inch of the bottom of the screen.  It has reached the point of my
    throwing the TV onto the trash heap.  Have tried to carefully clean the
    screen on the outside.  This is obviously in the deeper workings of the screen.  My best guess is that it is a poor quality or damaged in shipment
    screen with delayed results.   Have had the TV set for approximately 2 years.
  • Anonymous Mar 21, 2008
    Same problem as glowreeah's ! Brown splotch down the center. Can't even find local tv repair shop to work on JUNK Protron SET. Shop NBC and Protron what a RIP OFF they even beat me out of 100.00 rebate. I've told everyone I know about them both. DO NOT BUY !!!!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
I'm guessing you have a matt finish to your screen in which case it is semi flexible plastic. It's important not to use anything abrasive or acidic as it could leave an etched mark. The best think is to soak a tissue in a solution of bicarbonate of soda and warm water (about 1 teaspoon to 1/4 pint water), then with your TV switched off, tape the tissue over the stain and leave overnight. Gently rub the tissue over the area the next morning and the mark should have gone or at least be less noticeable. Hope that helps :o)
Posted on Jan 27, 2008
Spots of Color on Screen of HD 32"
First You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
What kind of insect surrounds an egg with sticks attached to windows
it is a large brown moth with spots on the wings
the eggs can be found attached to anything besides windows
May 24, 2017 | Audio Players & Recorders
What is the difference between a bug and an error
The first physically documented computer bug was documented by Dr. Grace Murray Hopper when she was programming the Mark II Calculator (computer). When the system was not functioning correctly after troubleshooting the system, she found a moth between contacts of a relay. After removing the moth the system functioned and the moth was taped in her notes documenting the bug.
A computer error is displayed when a known problem in the computer code (program) expects a result from the hardware (electronic circuit) or software, and it does not fall within the code parameters. In most cases the error can return information about why the computer had a problem.
Conclusion:
A bug is an unknown failure of the system which usually is intermittent and causes the system to crash or results in some type of failure. An error returns information about the system failure which is displayed or documented on the display or in log file.
Jul 02, 2010 | Contax Cameras
Is it true that if you use moth balls with the fuel in my kerosene heater it burns cleaner & there wont be any build up on the wick? I get alot of soot build up on the wick of my kerosene heater &...
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Feb 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
SMALL MOTH
Unplug the set! Snap the trim ring off the front of the set and you may find a few screws or the front screen may just pop off. Then you can clean the screen and mirror. Be sure not to bump the color guns this will change the alignment of them. Be careful not to spill anything in the set. This is a relative easy fix.
Aug 18, 2008 | Sony KP-57HW40 57" Rear Projection...
Protron PLTV-32 Television Logo
170 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
