Question about Bosch WFMC 3200 Front Load Washer
Rubber gasket around opening
The rubber is held in place by a spring and wire which has come loose. There are also tears in the rubber. Can't reapply spring wire to hold rubber.
  • Philip1954 Feb 08, 2008
    I have the same problem, but was able to re-install the damaged gasket with the help of my wife (you need extra hands to replace the wire spring around the gasket). I still need to change the gasket since it is damaged, but cannot find the exact part number (Bosch was of no help here). I did manage to speak to a couple of parts suppliers, and one mentioned part number BT-243834, but internet research shows this as a part for a Bosch Thermador, not Bosch Nexxt. Also the prices for this part vary considerably, from $52 to $95 in the US, and as high as $141 in Canada (where I live).
    Any ideas?
  • chebeague Feb 12, 2008
    How do you get the wire back on the gasket? The spring is very tight, and even with two people we can't stretch it to get it around the gasket. Do you have to use a tool (maybe a screwdriver) to hold it in place? This is what I need help with. I have a Bosch WFMC 3300
    Thanks,
    Marie
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Posted on Jan 27, 2008
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
Rubber seal and wire has come off the inside of my washer, how do you fix or do you need repair service?
Wire and bellows repair.Check to see if the rubber gasket bellows has a tear. If it loooks good the bellows goes over the front lip of the washer ,than place the wire that should have a spring attached over the lip. you will need a extra set oh hands to help hold the wire in place as you use to butterknifes to slde the spring over the lip.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Wire that holds the rubber gasket came off
can usually take to people if you are not familiar.the spring does down towrds the bottom of the boot in the middle of the boot start with the ring at the top and go down both sides the have someone hold it in place about the 10 and 2 o clock positions while you use your hands or small screw driver and finish putting the ring in place
Jun 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
The rubber piece in the front of the washer is pulled up and the metal large ring is not in place not sure how it goes back on
If you are referring to the wire hoop retaining clamp that holds the door bellow (rubber gasket) in place, it installs the following way:
1. Install the bellow over the frame of the door opening and ensure its seated and snug all the way around the perimeter.
2. Beginning at the top of the door, start inserting the wire hoop into the rubber groove of the bellow that is located around perimeter of the door frame. Make sure to wire spring points towards the 6 o'clock position.
3. As you work your way around the door frame to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to get it to snap into place.
It would be helpful to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
The wire hoop is known as the front door bellow clamp.
If you have any problems, or further questions, please let me know. I hope this helps you.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
239 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
