See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Ya, when the car is running, you're using power from the alternator. So it will show 14 volts as long as its running. The fact that it won't hold the charge means the battery is shot and you probably need a new one
Sounds like a problem with the cooling system - when it has enough coolant it won't run too hot so won't trip ''reduced power mode". If coolant is at max already it's either the water pump or the thermostat having a problem.
you say stopped running steering locked up the steering lock is mechanical and has nothing to do with the actually running of the engine so i am presumming that the car was idling stalled on its own and the steering as you tried to restart it locked or the steering won,t turn it won,t if the engine s not running as it is helped by the power steering pump which doesn,t work unless then engines running but if the steering has just locked up then you won,t be able to turn the steering in which case you,ll need a new steering lock not that big a job yates210456
