Alesis RA500 amp - channels crackle, distort, cut out
I have a 15-month old Alesis RA500 amp with a problem - for a few months now, often the left channel would be "crackly" and cut out, but then seem to "warm up" and be fine.  Now, the right channel started to behave like that, even after it had been on for a few hours: it would get crackly and distorted (esp. if fed low-frequency content, like bass guitar) and then cut out entirely.  There's no problem with load; I'm using 6 ohm Polk Audio Model 11 studio monitors (circa 1982 and still some of the best speakers I've ever heard, IMHO).  Note that these behaviors have nothing to do with volume, either - I typically run the amp's controls between 9 and 12 o'clock.
The amp is only about 15 mos old, so I wouldn't think caps are going yet from age, unless they were crappy to start with.
  • zahzah Jul 21, 2008
    My RA500 is a few years old, now. It's always had that crackling problem from time to time, exactly as previously described under the same circumstances. Except, when it became too irritablle, I would "exercise" the speaker output jacks, jacking them in/out a few times, believing ther to be a dirty jack. BUT NOW, it's developed a constant loud "ground hum" with no input signal AND volume knobs turned down to zero ! Hum is present on any AC circuit I try.
  • 682 Answers
You have a problem in output stage and output ic need to check or replace.
Posted on Apr 24, 2008
Audio Output signals distorted
Without knowing what make and model of whatever you're asking about we can't be specific.
But if all outputs are distorting. Either the preamp is driving the amp too hard, or the amp is fried and needs repair/replacement.
Aug 30, 2016 | The Music
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
Amp cuts out after a while
My Alesis SA-300 started the cutting out when at moderate levels some months ago... Well, Radio Shack has instant gratificaion for those who have one in the neighborhood. Part number 275-249 will do the trick!
I replaced the Dong Woo part with the Radio Shack item and the amp is back to its old self... maybe even a little better. Loud, clean and steady.
Thanks to all you who have contributed to this thread.
Oct 17, 2007 | Alesis RA-150 Amplifier
647 people viewed this question
