Question about Panasonic KX-TGA600B Cordless Expansion Handset
1 handset "no link to base', picked up a new one but the de-re register procedure did not work, still have the same msg with the new handset
Picked up a new one but the de-re register procedure did not work, still have the same msg with the new handset
  • Anonymous Apr 16, 2008
    Is there a specific procedure to re-link the hanset to the base? I have lost my manual.
  • guilhas Mar 13, 2009
    Headset stuck in #1, cant be unregistered and cant be re-registered with another number. The same info returns "no link to base". If a "reset" procedure exists, that can be useful. Base is ok and works fine with another 2 units.
    Thanks
    Novelist:
  • 106 Answers
You may have a bad base. Do you have other handsets that are running okay on your base? Are you confident your going through the registration procedures correctly with the replacement handset? Did you have a storm come through preceeding your problems?
Posted on Jan 27, 2008
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
is still blinking.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Deregister procedure for at&t el52400 handsets
1. To de-register the orphaned handsets from their old base:
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 25, 2011 | AT&T E5640 Phone
I had to purchase a new AT&T cordless phone system since my last set was destroyed by lightening. My old system was CL82409 and my new system is CL82209. I have 3 expandable handsets from the old...
According to the manual starting on page 52, you need to de-register all handsets then re-register the handsets one at a time. The manual covers both cordless model numbers so the handsets should be interchangeable. I have included a link where you can download the manual if you need it.
http://att.vtp-media.com/ecp/documents/product_Product/127/UserManual/1082/cl82209_manual_i3.pdf
Mar 27, 2011 | AT&T Lands Phones
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
ModelKX-TG6051BSAYS NO LINK TO BASE MOVE CLOSER TO BASE, duh,i have it sitting on base all day,when go to make call it says no link to base.why? I did unplug roommates thought would work.But now cant even...
Your handset has somehow lost its ability to see your base. Try re-registering it to your base. To do so, at the handset push MENU 001 . Then at the base, push and hold down the INTERCOM/LOCATOR button down until the IN USE light begins flashing. Then at the handset push OK, and within a few seconds it should beep and be registered. If first not successful try again. If it still does not work, try de-registering the handset, then repeat the registration procedures I described above. Here is a link to the manual that describes these procedures, look on page 39. http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions/details-KX-TG6051M
Feb 26, 2008 | Lands Phones
Panasonic KX-TGA600B Cordless Expansion Handset Logo
535 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
