Question about Blaupunkt PA4100 Car Audio Amplifier
Replacing a Blaupunkt Reno with Florida
Hi, I'm Barry. Can somebody tell be the pinout (8-pin circular DIN) for the preamp out connections for a Reno (OEM in a '89 Porsche 911)? The car came with a Reno radio connected to an exteranl amp. The Reno preamp out connects to the external amp's preamp input DIN connector. I need to know the pinout for the preamp DIN connection (8-pins).
  • Alex
    Alex May 11, 2010
    If you can take a picture of the cable and post it on this site or email it to me then I should be able to help you, I just dont quite remember the pin layout and the color codes. try taking a pic and send it to me or post it.
    My email address is
  • 62 Answers
This is a PIC mybe can be help you...
Posted on Feb 25, 2008
How can i take my carradio out, and replace it
Posted on Feb 26, 2009
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
How do you wire it in? Orion 300 prq equalizer
the prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Aug 09, 2013 | Orion 2500D Car Audio Amplifier
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Someone gave me a YST-MS50. The left speaker (no controls) does not work. It is not the speaker or the cable from the main unit to that speaker. I find that only 7 of the 8 wires in the 8 pin cable going...
If you don't get it to work would you be willing to sell me the right satellite speaker with the controls? email me: (just take out all the dots)
Dec 05, 2010 | Yamaha YST-MS50 Computer Speakers
Screen wiring pinouts accoustic solutions dvd 263
if you check in and tells you which pin is what. i have the same system and i tryed only using 9v input not any video input. it only stays in standby the remote does nothing when i try to use it. if you got any solution please email to me in
Sep 27, 2009 | Durabrand Portable DVD
Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Apr 24, 2009 | Audio Players & Recorders
Blaupunkt PA4100 Car Audio Amplifier Logo
815 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
