Question about Sewing Machines
Loud noise while sewing
The machine makes a lot of noise while I'm sewing and when I check the bobbin it has little nicks all around the outside edge.
  • tf65 Feb 02, 2008
    My machine is making very loud noise while sewing, I dissamble & cleaned it & put oil in it but the problem is not fixed. There's nothing wrong with the bobbin.
  • orrmarie Jun 15, 2008
    I am also hearing a loud knocking from my Singer 7436. It was purchased for me at Christmas and has been used only a few times but I heard the noise from the first time I used it. It gets much louder when I sew over thicker areas with more than two layers of material even if it is very thin material.
    New Friend:
Posted on Mar 06, 2013
  • JUDY STEWART Mar 06, 2013
  • Sewing Machines Master
  • 1,388 Answers
Could you let us know which machine this is.....
In the meantime....the damaged bobbin is not good, replace it/them........if you have a top loading drop-in bobbin, check for needle damage on the plastic bobbin case (remove needleplate to access).
If there is evidence of needle strikes, if mild, you could try to use very fine wet & dry emery paper to smooth, if severe, buy a new bobbin case.
There may be a load of lint under and around the bobbin case too, remove and clean up this area. If very dirty, use methylated spitit on cloth or cottonbud (QTip) to remove grime (don't soak)
Posted on Jan 27, 2008
Why does the needle thread keeps on breaking on my elna envision 9008
There could be several reasons for thread breaking.
1) Incorrect threading. A guide has been missed or the thread path is incorrect. Consult the owner's manual. Remove all the thread and rethread from the beginning.
2) Tension is too tight. Tension setting standard is around the midway point between high & low number. Also check that the bobbin tension has not been set too tight so upper thread is being pulled to the underside of the fabric. Make sure the bobbin thread is wound smoothly on the bobbin--try a different bobbin. To insure the thread is seated completely in the tension disk, Always Raise the Presser Foot when threading the machine.
3) Install a brand new needle. Make sure the needle size/type are compatible with the thread and fabric.
All About Needles
4) There could be burr or nick somewhere that is catching the thread. Make sure the thread is not hanging up on the slit of the thread spool. Sometimes the thread will loop around the thread spool causing thread breakage. Check the needle plate and the bobbin area. If there is a small nick, it usually can be gently smoothed with a fine emery board. If not, then a technician's assistance or a replacement part may be required.
5) Void old or bargain bin threads. Spend a little extra for good quality sewing thread and increase the chance of sewing success.
Sewing Machine Problem 1 Thread Breakage
NMSU Checklist of Common Machine Troubles
If the issue is not resolved, service is probably necessary.
Jul 21, 2016 | Elna Sewing Machines
My futura machine keeps every few seconds and stops sewing, what the problem
this was my first problem - if youhave had a "birdsnest" you probably damaged the bobbin case - take it out and run your finger aroundthe outside edge . You will probabaly find a nick where the needle has crashed down on the bobbin case. If you can sand it smooth it may start pulling the thread around the bobbin again. Twice I have had to replace the bobbin case. It is cheap just google on the internet. Now I have a spare if anything happens. I also found if you stick to the embroidery threads and not try to use up old or cheap thread it will run more smoothly.
Dec 01, 2012 | Singer CE-100 Futura Computerized Sewing...
When I push the needle up / down button, it does not work., and the machine just squeeks.
some thread might have caught in the metal case on which the bobbin rests. There is a tiny hook in the center that the thread travels around before being picked up by the needle thread to form the stitch. Also, check your bobbin itself. Feel around the outside. If you feel any nicks or burrs, throw that bobbin away and get a new one as the thread is catching on the bobbin itself and throwing the timing off.
Check your needle to be sure there are no burrs or nicks on it. Always use a new needle with each project and if the project is a large one, you will have to change your needle a few times. Needles are not that expensive and make a world of difference in sewing.
One more thing. If your machine manual shows a small "arm" that fits over the bobbin to hold it in place, and that you can remove for cleaning, be sure that it is inserted all the way in and holds the bobbin securely as this will cause the bobbin to "bounce" inside its metal bed and cause the thread to tangle up in the machine.
Jul 20, 2011 | Singer Quantum 9910 Computerized Sewing...
The needle keeps hitting the bobbin holder, it has actually nicked it. I cannot sew, the bobbin thread just jams up in a bundle and the machine jams
Check to make sure the needle is up all the way into the clamp. If the bobbin case now has sharp edges from the impact. polish away the sharpness with an emery board or simular. Once a needle is hit it canot be used again so always use a fresh needle.
Dec 12, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Having issues with my Se-270D can you help
The brother machines are notorious for jamming if there is even a tiny bit of lint in the machine. Take out your bobbin, unscrew the plate, take out the bobbin holder. Use a pipe cleaner or paint brush to brush all around inside the machine and pull out any little threads/lint that has collected in there. Replace the bobbin holder by lining up the screw toward the front. Replace the plate and screws. Make sure your bobbin doesn't have any little nicks around the edges that could catch thread. Replace the bobbin and rethread. Replace your needle (this needs to be changed often) rethread your upper thread. Test stitch.
Mar 16, 2010 | Brother SE-270D Computerized Sewing...
When I try to sew my machine jams a little every few seconds and is not sewing on top. When I try to remove the fabric it is stuck and there is a mess of thread underneath. I have cleaned and oiled my...
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have an older machine - Riccar 3600 -- and the spool thread keeps breaking while sewing. What can I do?
Here are some things to try.
If it's Your upper thread breaking:
* Rethread your machine
An incorrectly threaded machine can cause thread to break.
* Decrease the tension on your machine
The tension may be too tight for your thread.
* Reposition the spool of thread on the spindle
You know that little nick in the edge of a spool that’s used to hold the loose end of the thread? Your thread may be catching on this nick as you sew. Place your spool so that this nick rests against the bottom of the spindle.
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly, usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Change your needle
Your needle may be bent or dull. The eye of your needle may have a nick in it that’s cutting the thread as you sew. Or your needle may be too small for the thread you’re using, in which case, change to a larger needle. And make sure your needle is appropriate for the weight and type of your fabric.
* Change your thread
Your thread may be weak. Or your thread may be fuzzy and irregular, causing it to catch in the eye of your needle as you sew. Cheap thread tends to be weak and fuzzy, so make sure to
use a quality, brand name thread. And if you’ve been sewing with an older cotton thread, which can dry out and become brittle with age, try a newer thread.
* Check your presser foot for damage to the needle hole
A burr in your presser foot’s needle hole may be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
* There may be a burr in one of your thread guides, in which case, you may need to have your
machine professionally serviced to have the part replaced.
If it's Your lower thread breaking:
* Reinsert your bobbin
Your bobbin may not be seated properly in its case.
* Rethread your bobbin
Your bobbin may be threaded incorrectly or the thread may be tangled.
* Remove some of the thread from your bobbin
If your bobbin is very full (if it’s hard to insert into the case, it’s too full), this may be keeping your bobbin from turning smoothly.
* Rewind your bobbin thread
If your bobbin thread is wound unevenly, this may be keeping your bobbin from turning
* Try a new bobbin
* Clean the lint from your bobbin case
Lint in your bobbin case could be keeping your bobbin from working properly.
* Check the needle hole in your throat plate for rough spots
A burr in the needle hole of your throat plate, usually caused by the needle hitting the throat plate, could be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
I hope one of these solutions work for you.
Sep 13, 2009 | Riccar Sewing Machines
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
May 22, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
429 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
