Question about Marantz SR8500 Receiver
Marantz SR8500 Attemptimg to set up plasma (Samsung 42 inch) with Marantz appliances. The problem is that the HDMI cable takes the surround sound away from the amp and plays movies in stereo (front speakers). I would appreciate any assistance.
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
No picture, just sound on my 50 inch plasma tv
Does it show a Menu at least? If it does then just switch through the INPUT until you see a picture. Cables most likely to be Video 1, 2 or 3. Video games "LINE", or HDMI..of course "HDMI".
Your remote should have an "INPUT" button.
Aug 21, 2010 | Samsung SPN4235 42 in. Plasma HDTV
4 inch horizontal black bar across my 42 inch dell plasma. tv doesnt shut off and sound ok
The thick bar you are seeing could be a couple of things - either your HDMI or any other wire your connecting has been run too close to electrical lines, or your cable incoming needs to be grounded and/or filtered. It could also be a defect in the TV.
Sometimes it will just go away.... Its hard to tell without actually looking at your setup and television.
Feb 25, 2010 | Dell W4201C 42 in. Plasma HDTV
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
New
Try to connect TV AUDIO OUT to TV AUDIO IN or AUX IN on receiver, when you get sound from TV, select SURROUND mode on receiver.
Sep 30, 2007 | Samsung HT-X40 System
Marantz SR8500 Receiver Logo
259 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
