Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi when i go to turn the tv on it shuts off right away it won't stay on model wt- a42 or wt- 42311 serial 111343 42 inch projection tv we had dish network installed about 5 days before. if that might help. we have not had any problems with the tv in the past we did have direct tv but switched. my email unicnt3@msn.com Patricia Menzies
  • 871 Answers
1. Might be IR interference. Try putting black tape over the IR eye on the TV and see if it goes away.
2. If the TV is powered by a cable box or DVD player, plug it directly into the wall.
3. Look in the menu structure for timers and make sure they are all disabled.
4. Make sure that no one is pranking you by using a hidden remote.
Posted on Jan 27, 2008
    Sergeant:
  • 226 Answers
Have you tried using your remote control?
does it shuts off?
its something to do with the circiut board of your tv. if not its simply the power switch of the tv. that can be replaced bby repair man.
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
Mitsubishi wt-42311 green light flashes and turns
Mits are bad about power supply capacitors failing. It can be fixed fairly cheaply, but requires some skill at disassembly of the tv and unsoldering/soldering.
Dec 10, 2009 | Televison & Video
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi WT-46809 Turns on with Power light then turns off
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Jun 07, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
