Question about Kenwood KAC-9152D Car Audio Amplifier
Is it not bridgable
So this amp isn't bridgable?
i cause i bridged it and it stiil works but if i just hook it up regular
than would i get mor watts? i have it hooked up to a kicker cvr 15".
  • 631 Answers
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Posted on Jan 28, 2008
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    How can a person bridge a boss cx 150 to operate on one woofer, it works when connected to either output and when connected to one neg and pos from other channel, does the other pos and neg need connected
    basically to bridge a amp if you look at the speaker connections on the amp it will say + - / + - those r your 2 channels above below or next to one + of one channel there should be an additional + sign and the same thing with the - of the other channel those are your bridged positive and bridged negative how you hook it up to bridge it is to connect both positives from both speakers to one positive and both negatives from both speakers to one negative this will drop the ohms in your amp as well as your speakers giving you more if your amp is not bridgable then you will not see the extra + - signs you can still attempt to bridge it but is a good posibility that you could blow the amp because it can not handle operating at a lower ohm rating if you are hooking one speaker up you do the same but just hook one speaker up instead of two
    Feb 28, 2010 | Boss C150 Car Audio Amplifier
    How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
    • Amplifier Type: Dual Channel
    • Bridgable: Bridgable
    • RMS Power at 4 Ohms: 150 W x 2
    • RMS Power at 2 Ohms: 300 W x 2
    heres a link to a stats page for the zr600>
    http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
    Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
    Sony X-Plode amplifier. NOT working
    It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
    Oct 11, 2009 | Car Audio & Video
    Watt size fuse do i use to connect a 350 watt stereo/bridgable amp using a 4 gauge power cord
    You use the same amp fuse as on your amp, nothing larger. The fuse just keeps the wire from overheating/shorting and causing a fire.. IF you amp has a 30 amp fuse then you use a 30amp fuse off the battery
    Sep 10, 2009 | Kenwood KAC-629S Car Audio Amplifier
    I have amono 600.1 amp
    if its mono there is nothing to bridge
    Jul 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
    Subwoofers
    This will depend on the amplifiers capabilities.
    I will give 2 different scenarios.
    #1 Stereo configuration
    If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
    Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
    #2 Mono Bridged mode.
    If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
    Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
    So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
    For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
    Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
    Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
    Wiring installation on Majestic amplifier total 60watts 2x30 model# ma-60
    To install the amp you need a amp wiring kit they range from $15 and up depends on how many watts u have.Once you have the wiring kit start with the ground wire it needs to be no longer then 24 inches long the shorter the better find a good ground in the trunk or where ever you want to install the amp make sure its metal to metal no plastic paint or any other debrie is in the way of the metal.If you can't find a paint free surface all you will need to do to fix this is sand off some of the paint and then ground the amp.The ground wire needs to be connected to the amp before any other wire once you have the ground connected then connect the battary wire make sure you have the right size inline fuse on the battary wire that also depends on the watts of the amp.once you have those 2 wires connected then u will need to pull the stereo out of the dash and hook up the remote wire to the power antanna wire if you have a factory car stereo and don't have a power antanna you can try one of these solutions 1st one Run the remote wire from the battary wire on the amp and use a toggle switch between the remote and battary wire or you can run the remote wire from the amp to the fuse box of the car and hook it up to a fuse that only works when the key is turned on.Once you have all this hooked up its time to hook up the subs/speakers on the amp it should indicate if its bridgable it will show lines from one positive and one negative and at the top of the lines it will say bridge but if not the just connect the speakers positive to positve and negative to negative.If it is a bridgeable amp i would only recommend hooking it up bridged if you are hook up subs if you are using 6x9's on the amp you don't need to bridge the amp.If u have any more ?'s just ask i can help with this i've done this alot.
    Sep 03, 2008 | Car Audio & Video
    Bridging
    Yes and no lol. I sold that product about three or so years ago. That amplifier is whats called a mono amp. The outside shows two channels but they are still tied together. Think of it as a hose with a Y on it so two lines can run out from it. Its still the same amount of water whether you use both hoses or not. So bridge it if you want to but it will for looks and looks only. Note that amp is only two ohm stable so be careful what woofers you use. You will want two single 4 ohm woofers for a regular instalation. DO NOT USE Dual 4 ohm speakers Good Luck
    Nov 17, 2007 | Car Audio & Video
    Kenwood KAC-9152D Car Audio Amplifier Logo
    126 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
