Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold side by side refrigerator relay compressor?
Hi. My 'fridge isn't cold. Everything seems to match the description for an issue with the relay compressor. It seems to be working, light's on, fan's on, sounds like it's getting cold, motor runs, then clicks, turns off, repeat every three or four minutes, inside is warm. I took the cover off and vacuumed out the vent really well, then flipped the breaker leaving it off for a couple of minutes before restarting. Nothing. I turned the temperature dials up down and all around. Nothing. How do I find this magic box to try triggering the switch? Not even Whirlpool's site has the manual available. Best of all, it's sunday, the food's warm (just went shopping of course!) and there is not a repair tech in town available 'til tomorrow? Please help! Just in case, the model numbers GD2NHGXLQ00 made 08/02. Thanks!
p.s. should i just turn it off it the meantime, the fan just seems to be making it warmer?
  • 7 more comments
  • ta_va Jan 28, 2008
    I'm in Philadelphia, so it's pretty chilly outside, about 45
    degrees. The 'fridge hasn't been moved at all in quite a long
    time (I think I moved it a couple inches forward to paint last year but
    that's about it). It's in the kitchen, ceremic tile floor with a
    full wall on the freezer and back side, cabinets above (with about a
    four inch clearance) that extend across the back third of it's depth
    and a counter/dishwasher about an inch away that's about half it's
    height, same depth on the "fresh foods" side. It's been packed a
    little full lately, it's always pretty full but maybe even more so the
    last two weeks or so. We also recently started accumulating more
    stuff on top, recently the available 2/3's have been pretty covered
    with cereral boxes and that sort of lightweight stuff primarily.
    I tried to shut it down again, this time I turned the breaker off and
    left it off for 2-3 hours and I removed more than half the
    contents, cleared space from the top (ceiling) of the top shelf in the
    fresh side and removed nearly everything from the top of it. I
    left only a largish metal serving bowl filled with some really light
    items, but made sure it was all the way towards the back of the freezer
    side as it seemed like the main temperature gauge was likely in the
    "ceiling" of the fridge side.
    This time I turned it back on (set to the coldest settings on both
    sides) and it stopped "clicking" and seeming to turn on and off so
    often. It also seems like the air coming in (on the freezer side)
    is colder and it smells a little like coolant (not any more than
    usual). The vent area from the freezer to the fridge side seems
    to be working well. And I double checked the door switches (to
    show whether it's open or closed) on both sides and they seem
    fine.
    It feels a little colder. A little. It's been six hours since I've
    turned it back on and glass on the fresh side feels cool to the touch
    (instead of tepid) but that's about it. The ice bags I put in
    this morning are still (mostly) solid.
    Now it's running, clicking and stopping only to repeat again every
    couple minutes. So the "okay, maybe it's working hope" lasted
    about an hour or so after I turned the power back on.
    Also, about two or three days ago I noticed a humming one evening like
    it was constantly re-setting. Like the sound it makes as the
    water spout refilling directly after use. Except it would hum,
    for maybe a second or two, stop completely, for less than a second,
    then repeat. No clicking. Different than the sound of it
    turning on repeatedly now. Also within this week we noticed a
    electric smell one evening. Like a overheating electric
    smell..... it was just that one time (though it was quite significant)
    we open the windows, unsure that it was definitely in our house (we
    have a rowhome in the city) and it disappaited and we didn't smell it
    again after that.
    Okay, that was a lot of information! I hope it's helpful (and
    pertinant!). Thanks so much in advance! I'm feeling at my
    wits end! Thanks!
    The tech has (finally) came. He removed the backing and manually
    metered the compressor. Turns out to indeed be the starter.
    Unfortunately, it's not the a "spare change" repair ($180).
    Alternatively, it's repairable and NOT the compressor, so we don't need
    to purchase a new unit.
    Thanks for all the help!
  • Rocketbluez Mar 03, 2008
    Hi, my refrigerator doesn't seem to be getting cold enough, I also notice that around the rubber in the freezer as well as the refrigerator it hot. I have them both set to the highest temperature. Inside seems a bit cooler, but around the door, it is hot. In the door it seems not to be getting any cooler. I had to throw milk that was in the refrigerator because it was goinh bad, and this morning I had to throw away some bisquits that was spoiled in the door. HELP!!!! I have a whirlpool side-by-side white ED22PEXHW01.
  • Anonymous Mar 23, 2008
    Switch on refrigerator sound like its starting the cut off. Not cooling blowing warm air.
  • Anonymous Mar 26, 2008
    refrigerator made date 09/ 24/ 01 side by side black on black sticker on back of box w430 111 32651-3 sxsdspb ed22pexhb frezer warm refrigerator not cold enough white swich pluged into black canaster compresser clicks on and off about every 10 seconds fan aways runs
  • Anonymous Jul 28, 2008
    Hello! Have an "03 Kitchenaid side by side atainless steel refrigerator..Freezer and fridge inop..Lights, fans are working..Doors okay..Smelled a burnt metal before it stopped cooling..Can it be the compressor, motor or starter?
    Just turned it off and on after 20 minutes, no change..Brother suggested to unplug the unit and wait an hour or two and plug it back in...Haven't done it yet, tomorrow, no one to help move the fridge....Any other idea?
    Thanks a bunch!
  • Anonymous Sep 25, 2008
    Whirlppool Gold SBS Refrig. Compressor Short Cycling - Losing Cool. Please Help
  • dutch10 Sep 27, 2008
    I have the same problem. My compressor cycles on and the cycles off after about 10 seconds. It keeps happening about every 5 minutes. I'm hearing the same sound. Does it sound like the thermostat or the relay?
  • lisminzo Nov 11, 2008
    fridge isnt cooling
Sounds like the relay switch. Light works, fan works, but is not cold. Also if you smell a burnt metal very strong smell. Relay switch must have burnt.
Posted on Oct 28, 2008
    Problem Solver:
  • 5 Answers
Turn it off for an hour or so and give the coils time to thaw just in case they somehow froze up. also if the frig was tilted in the wrong direction (which it doesnt sound like it was since it has food in it!!!) it could need time to let the refrigerant and oil settle back into the compressor.
where are you located (cold or warm climate)?
and where is the frig located (in your home)?
Posted on Jan 27, 2008
  • Ian Fair Jan 28, 2008
    I'd say it could be time to call a service guy ... or if you know someone handy with appliances who would be willing to look at it. Its extremely hard to diagnose refrigerent problems without being at the unit itself because there are SO many different factors. it could be a bum switch or thermometer that helps the computer know whats going on with the mechanicals and electrionics of the whole system. Because of the chemicals and high pressures often involved with and the very delicate sequence of operations necessary for optimal performance refrigeration equipment there are so many safety devices like high and low pressure cutoffs temperature monitoring equipment etc etc etc. without being there to put my meter on it ... i dont watn to point you too far in the wrong direction.
    the burning electrical smell scares me a little. hopefully it was just some dust or something that landed on the hot compressor, but it very well could have been a small internal computer board finishing its service life or even worse ... the refrigerent in the compressor getting too hot and burning (not fire burning, but breaking down burning). normally you wouldnt smell this until the compressor is removed becuase it is a closed system.
    Hope you dont get too frustrated with it. I know how applicance problems can be such a PITA. Good luck. Sorry I couldnt help more.
    ijf0
    phew!
    hope you didnt lose too much food
2 Suggested Answers
SOURCE: whirlpool gold side by side refrigerator relay compressor?
realy yes
Posted on Nov 29, 2008
Hi, I have a whirlpool gold side by side fridge/freezer. I came home the other day and water all over the floor. I opened the freezer and it wasd hot. Opened the fridge, same thing. Light and fan work and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
Whats a relay on a side by side fridg
heatman101
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge blowing air but seems warm
You probably have an issue with the compressor or components attached to the compressor (e.g.: relay, overload and capacitor (if applicable)). Contact an appliance service company.
Apr 14, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator won't get cold
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer defrosted everything- fridge seems cold-
Sounds like the overload/relay is bad . Pt# 2188831 . This is the part attached to the side of the compressor , with 2 or 3 wires connected to it . Easily replaceable . Also , make sure the coils under the front of the refrig at the bottom , is clean of dust , lint , pet hair , etc.
Sep 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge not cooling 60 degrees
hi thanks for the question did you clean the coils at the back by the compressor if not clean the coils its very important try that thanks the appliance doc
Sep 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
4,295 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
