Question about Denon AVR 3808Ci Receiver
Denon 3808 I am trying to connect a pianomation qrs system to the denon receiver... have it on ipod/vcr connected via red/white cables.... cannot get any sound out of the speakers...
NetPiano has removed DRM from it's downloads. The files are now mp3 files. You can copy them to CDs, Flash memory or mp3 player and play them on your Pianomation. Call Tim at QRS for more help in setting up your Pianomation unit. (814) 676-1005
Posted on May 04, 2009
  • 119 Answers
Plug the RED/WHITE RCA plug into the front V.Aux input on the front of the Denon and verify that the piano is outputting a signal
Posted on Mar 03, 2009
4 Suggested Answers
SOURCE: how to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Posted on Jun 28, 2007
SOURCE: Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Posted on Apr 16, 2008
smarthome2
  • 1114 Answers
SOURCE: no picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Posted on Feb 28, 2010
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
No audio thru receiver with xbox360
Get some audio cables from radio shack or gamestop and use the regular audio jacks on the xbox to connect to your receiver.  Your video will be HD, but your audio won't.
Dec 22, 2008 | Denon AVR-1603 Receiver
Denon ASD-3w ipod dock not being recognized by denon 3808
I successfully connected the ASD-3W to the Denon 3808CI using the supplied AV/Control cables (dock control, L & R audio, S-video). I used the video and audio input connectors marked VCR (iPod) on the 3808CI and used the default settings. I used the connector marked Dock Control for the control cable. These VCR (iPod) connectors are different than the input connectors marked VCR. I turned the source selector to VCR/iPod Stereo and operated the GUI using the ASD-3W remote control. I was able to play music and video.
Nov 16, 2008 | Denon ASD3W IPod Networking Dock Docking...
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Apr 03, 2008 | Denon AVR588 Receiver
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
How to connect using a LCD monitor, cable box, DVD player
Jun 21, 2007 | Denon AVR-886 Receiver
Denon AVR 3808Ci Receiver Logo
259 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
