Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinks twice pause blinks 4 times
Blinks twice thank blinks 4 times, a clicking/ sometimes chirping noise can be heard from the capacitor looking think with the bracket on it. is it worth replacing or kick it to the curb?
thanks a ton
Scott
  • 42 Answers
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Posted on Jan 28, 2008
Why won't my sharp lc-52d56u 52" lcd tv turn on properly
Check the diodes around the power section of the panel. it is possible one of them is bad or it does not allow the required voltage across.
Aug 21, 2014 | Televison & Video
Magnavox 51mp392h rear projection t.v's power button will blink continuous and there is a low chirping noise. T.V. does not turn on.
The chirping may be the key...When this is commonly the case its a convergence short. See more details on the site www.TvRepairKits.com - Look for a chirping repair kit for your model. Its a common issue
Mar 02, 2013 | Philips Magnavox 51MP392H Rear Projection...
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
Heard a loud pop and screen went dark. red light on front of tv flashes 4 times
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 17, 2011 | Panasonic TC-P46G10 Plasma TV
Sony KDL-46S5100 As the customer was watching it he heard a loud crackel sound and went dead. now all it does is click when I press the power button. No Bad Caps. Any suggestions? Thanks. Alltech TV Repair...
Let me know does power light is blinking on KDL-46S5100 tv front when it refuse to turn On?
If yes, how many times it is blinking as there would be 3 seconds long pause between blinks so count pause to pause and let me know to diagnose possible cause of problem and provide you its solution.
Thanks.
Nov 15, 2010 | Televison & Video
Hi, I have a toyota celica 1994. The yellow warning light (picture of a car with exhust flowing out) has come up. I don't have the user manual, so don't know what it means. Thanks
Does this light blink at all ? count the blinks. Sometimes it will blink three times, then pause then blink twice etc. Some variation of that? blinks once, then pause then twice. The first example is code 32, the second is code 12. These codes are in my manual, but you have to count them for me. Oh, by the way, is this a celica with the 2.2L 5sfe engine?
Sep 02, 2010 | 1994 Toyota Celica
I have a 12 bottle vinotemp that is making a chirping sound. The fan is slow and then faster, also there is a red & green lite on the circut board that flashes. Where can i see about getting this...
I have a different model Vinotemp, but experienced the same exact problem described here where the LEDs on the controller board blinks and there is a clicking or chirping noise. It turns out there was a bad electrolytic capacitor on the controller board that was visibly noticeable (it was bulging). Replacing the capacitor fixed the problem. On my model, it was a 1000 microfarad 16v cap, available at RadioShack or any store that sells electronic components for less than $1. Of course, you will need some soldering skills for this fix.
Mar 12, 2010 | VinoTemp (VT60GNV) Wine Cooler
TV turns on but turns itself off after short amounts of time
This set is equipped with LED diagnostics. Once it shuts down on the front of the set hold down the MENU and INPUT, (sometimes labeled DEVICE) buttons until the LED starts blinking a 2 blink sequence. For example one blink pause two blinks long pause and then repeats is the code for no problem. All of the fault codes begin with two blinks and then one through 4 blinks. I suspect that yours will be a 2 - 4 code because of loss of vertical sweep. Which is bad solder connections on the deflection yokes. A common problem with these units.
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sony TV not turning on!
this is almost certainly a ht proplem chech ht transistor by removal then turn tv on it should if so replace transistor be carfull high voltage may be still present on capacitors
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
428 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
