Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 51 in.
I NEED TO MOVE MY SET. CAN I DISMANTLE THE SET IN TWO PIECES MAKING IT EASIER TO TRANSPOR IT IN MY MINI VAN?
    Problem Solver:
  • 9 Answers
You can not on this set. The plastic chassis comes off easily but the mirror will not be protected. Leave it together and transport without tilting or laying down. Home Depot or similar will let you rent a pick up for $20. Well worth it.
Posted on Jan 27, 2008
Need to know how to dismantle
Set is not designed to be taken apart for moving---what do you need?
Mar 18, 2012 | Sony KP-53HS30 53" Rear Projection...
A 53 inch sony tv
blink red light and blank screen every two mintue
My tape (tdk mini dv 60) was damaged by my sony camcorder. i need help fixing it. it's twisted inside the cassette. is there a way to untwist and splice the damaged part out?
Well if it's not personnal? I would send it to a camera store and have them repair it. If it is personnal? I would set time aside and dismantle it remembering how it goes back together.
Jan 06, 2011 | TDK DVM60 Mini DV Tape
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Can I disassemble my Sony KP-57w-s500 to move from one room to another? It is too big in one piece. Can I separate the top from the bottom?
The only TV's I worked on that the upper and lower halves would seperate was a Hitachi 65 inch projection. So to sum up the answer, no you can not seperate this set.
Nov 03, 2009 | Televison & Video
Dismantling Printer to be able to carry down stairs.
Yeah. On the back of the document feeder there is one white molex connector. Unscrew the 2 thumb screws and lift up and puch back gently while lifting the feeder. The hinges will release pretty easily, then set it aside.
Also the paper tray, pull it forward, then up and out.
Removing those will make it much easier to move.
If you have a third tray, it should just be sitting on it. If the did install the clips, take the back cover off and remove the screws and plate. But most M20s with a lower tray, they just sit on the machine.
If it is conncected to a stand, just remove the back screws and lift it off the stand.
May 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Sony KP 43T90 Projection TV - use headphone
so u bought red white femail rca cables to mini sterio jack or bigger headphone style make sure tvs menu shows outoput on audio out on if u have option should be all it needs turn tv up after
Oct 06, 2008 | Sony KP-43T90 43" Rear Projection...
Sony kp-43ht20 geometry issue.
You may be setting your self up for a major headache. Trying to set convergence requires a professional pattern generator. There are also multiple phase adjustments to prevent linear drift of settings. Please spare yourself, take unit to a professional service!
Nov 21, 2007 | Sony KP-57WS520 57" Rear Projection...
3D picture stlye Samsung SP55W3HFX
Hi Ross, This repair is quite easy, But before I tell you how to fix the problem I need to know have you gone in to the user menu & tried adjusting the convergence This will save time & expense for you ? If you havent then try this first it may sort it out without needing to dismantle the set. Let me know how you get on by either replying to this post or let me know via email dyson@gawab.com Chris..
Oct 06, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
