Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
The water on the door works fine,but none is going to the ice maker. Worked fine for the last 2 years. It needs the filter changed but since the door water is working I didn't want to blame the filte
  • 90 Answers
There is a separate valve for the icemaker. It must be bad or have a bad connection.
Posted on Jan 28, 2008
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
I just changed the water filter on my whirlpool refridgerator and got the message off the door. Now neither the ice maker or water dispenser will work.
Possibly the filter is not in all the way or maybe it has a clear sticker/seal over the middle hole. Most filters need pushed in slightly while turning about a 1/4 to 1/2 turn. If it worked before the filter change it has to be in that area.
Apr 14, 2015 | Whirlpool Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
No ice in maker
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
Jul 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
No water going to the ice maker
Is the sensor that senses a full ice bin is a little light or it is a lever. If is thinks your bin is full it probably won't run water. There is a separate valve for the ice maker. It may be bad or have a bad connection on it.
Jan 27, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
