These are the instructions for a 4 cylinder motor.
CAUTION
Do
NOT remove the cylinder block or the radiator draincock with the system
hot and under pressure because serious burns from coolant can occur.
Care should be taken to NOT damage the radiator cooling fins or water tubes during removal or installation.
To install:
Here are the instruction for a 6 cylinder engine.
6-Cylinder Engines
CAUTION
Do
Care should be taken NOT to damage the radiator cooling fins or water tubes during removal or installation.
To install:
please let me know if i can assist you in any further problems you may encounter with your vehicle.
please do not forget to rate and comment about your experience with fixya today.
SOURCE: 1989 Dodge Shadow Radiator Fan Won't Come On
Sounds like the relay switch. Look in owners manual to see where it is located. I know some are under the dash and some in the engine compartment.
SOURCE: 1993 dodge shadow timing belt
get yourself a Hanes repair manual for your car. These books helped me alot with my 1995 civic. I believe they also have a book for your shadow. The book contains everything that you could probably fix for your car. From engine rebuilding to chassis repair.
SOURCE: my 1993 dodge shadow will not start, it will turn
Does it sound like a screeching or grinding sound? If so - it could be the starter is going out - there is a part called the bendix spring that is probably not engaging completely and it will cause the teeth of the starter to not fully engage the flywheel - which makes an awful sound.
Hope this helps and good luck!
KC GTO Dad
SOURCE: whats the average cost of replacing a waterpump on
Hi. Ok, the pump and gasket set will cost $42.47. If you are not Doing the replacement yourself, normal service tech fees will run in the $150.00 range, plus parts. This will lead you to a total of $192.47, roughly.
The margin of error in my figures will be $4.00. It all depends on where you purchase the parts. The general round off will be between $192.47 - $235.98, for the repair.
NOTE_ The price for a DIY will be $42.47, and a little sweat equity:-)
Have a great day, and thanks for using Fix Ya.
