Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
I have a Rainbow e series vacuum and the aqua mate II shampooing system. I need the instructions for the shampooing system, please.
  • 3 more comments
  • shopper32 Feb 24, 2008
    I have the rainbow aqua mate II, I have it hooked up according to the instructions, as I have several times before, but the water will not come out...yes there is water in the white container and yes I am squeezing the handle.
  • Anonymous Mar 04, 2008
    the can"t get hook on the wand please show how to put together
  • farrowfamily Mar 20, 2008
    The system is set up per the instructions, but unable to get water to come out of the white basin, even after depressing the handle
  • Anonymous Aug 04, 2008
    what hose to use to the vacuum
  • dcboyd Aug 09, 2008
    I appear to be missing the large white container that the water goes in....
  • 3 Answers
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Posted on Feb 13, 2008
    Sergeant:
    Habit-Forming:
  • Rainbow Expert
  • 138 Answers
You can download the Rainbow Vacuum Manuals.
RainVac
800-523-0510
Posted on Mar 23, 2016
6ya staff
SOURCE:
I turned the rainbow but there wasn't any water or shampoo coming out
Genuine Rainbow Aqua Mate Ii Solution Tank Manufacturer
www.sears.com/search=genuine%20rainbow%20aqua%20mate%20...
Sears"genuine rainbow aqua mate ii solution tank manufacturer" .... Hoover FloorMate Clean Water Solution Tank for all H3000 series Models, Part (59177076).
Jan 16, 2016 | Rainbow Genuine Water Tank Cap for...
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
We are also available if needed at Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Aqua mate II wont spray water
It is always best to run hot clean water through the wash cycle to flush out all soap when finished. This helps to prevent soap from drying in the lines and pump. You can also try this to help free a pump that is not working correctly.
Our tech. team is available if needed... Contact Us
RainVac
May 02, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have a Rainbow Aqua Mate II and have it all hooked up but water will not come out of the white tank. I am using the trigger but nothing is happening.
It sometimes takes a good soaking with water in the tank for a while. Maby a Week or longer, and it also takes a little running time. Not more than 10 minutes at a time, then cool for 30 minutes inbetween runnings, for the water to pump out of them. Do not even hook up any hoses, until it pumps water.
Thank you,
Ralph
Nov 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
New Rainbow aquamate. It is not letting the water flow through.
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Dec 22, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Dont know how to hook up the carpet cleaning part of the vacuum
You have to have the Aquamate II shampoo attachment in order to clean/shampoo your carpet. Go to the Rainbow website and you can purchase it if you don't already have one - if you do have one, this site also has simple directions on how to set up the Aquamate to shampoo your carpet.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I have my vacuum set to shampoo a rug, but cannot get the water to come out
If it is an earlier model Aquamate, then it is clogged somewhere in the hose, or the fluid control valve is clogged.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Aquamate 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=620181
Rainbow Aqua mate 2 (by 3 users)
Posted by nicks mom on May 24, 2008
I cannot get water to come out of the water basin in order to shampoo. It is all connected correctlyXThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
2 Other Users Have the Same Problem Comment by deucedown, posted on May 26, 2008 Same problem here, I have only used the shampooer twice and water will not come out of the basin. I need to shampoo my carpets today and this is very discouraging. Somebody please help. I hooked it up and followed the directions. Comment by Angela31, posted on May 26, 2008 We are having the same problem. Everything is connected and no water is coming out. We have only used our Aqua mate 3 other times. Please help. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum / Aqua Mate. It has been a long time since I have operated a Rainbow Aqua Mate so I suggest that The best solution to operate the Rainbow Aqua Mate is to contact the Rainbow Tech Support line listed below or to contact your local vacuum cleaner dealer and have them send out a Rainbow Aqua Mate owner’s manual so that you can operate the unit successfully. By listening to the 3 questions listed above the actual water basin I believe is the recovery water tank to be emptied when full and I believe that there is a separately bottle or tank that the solution goes in order to dispense the water.
If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister shampooer
i have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
Feb 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
4,252 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
