Question about Intel Motherboard
K9MM-V - Supreme Commamder
HI,
Just installed the k9MM-V with 2GB of memory and a GeForce 6600 AGP card. Updated bios and drivers this morning. Everything works fine except my son's Supreme Commander game which starts up OK but freezes the machine after a few seconds of play.
Any suggestions?
Thanks,
John
  • JohnDur Jan 27, 2008
    Yes, SP2 and got all of the updates.
    Thanks for the quick response.
    nVidia GeForce 6600 AGP X8 256 MB.
    Memoey:
    Tested at latency settings (4-4-4-12) at 2.1V
    SPD programmed at:
    JEDEC standard 5-5-5-18 at 800MHz.
    Two questions:
    - Which of these setting should be used?
    - Found the voltage setting in the bios, where are the rest of the settings?
    Tnx,
    J
    Sergeant:
  • 226 Answers
Video Cards Also known as graphics cards, these components are responsible for displaying 2D and 3D images on your monitor. 2D graphics are the regular pictures and images that appear on your screen while 3D graphics are mostly used in games and imaging. Most computer systems come with video cards that produce acceptable 2D results but there are reasons to upgrade.
Unless you have at least 32 MB of video RAM you can experience some image stuttering on your monitor when performing tasks like moving windows around and scrolling through text. This can become even more of an issue if you have a 19" or larger monitor. Most people with these monitors use a resolution greater than the 800x600 and maximum possible resolution is a function of the amount of memory a graphics card has. Therefore if you are getting a 19" or larger monitor you should have 64 MB of RAM.
Game designers continue to create more and more elaborate games, which require a yearly upgrade of the video card for the most devoted gamers. If you want to ensure that your setup has some longevity for playing the latest games you will want a 3D card with 128 MB of RAM or more.
The two major names in high-performance video cards are ATI and NVIDIA. Their cards all provide excellent performance with 2D graphic intensive programs as well as 3D games but as you move up their product lines you'll experience greater speed and more brilliant graphics.
Here's an overview of their product lines and whom they are geared towards.
Entry Level Mid Level High End ATI Radeon 9200 Radeon 9600/9700 Radeon 9800/X800 NVIDIA GeForce FX 5200 GeForce FX 5700/ FX 5900 GeForce FX5950/6800 try to use this specified video cards stated here:
Posted on Jan 27, 2008
  • 84 Answers
Did you reinstall XP?
  • 2 more comments
  • Nicu Jenunchi
    Nicu Jenunchi Jan 27, 2008
    http://www.msicomputer.com/product/p_spe...
    Main Memory
    Supports dual channel DDR2 533/667/800, using two 240-pin DDR2 DIMMs.
    Supports the memory size up to 2GB
    Supports 1.8v DDR2 SDRAM DIMM
    Due
    to the High Performance Memory design, motherboards or system
    configurations may or may not operate smoothly at the JEDEC (Joint
    Electron Device Engineering Council) standard settings (BIOS Default on
    the motherboard) such as DDR2 voltage, memory speeds and memory timing.
    Please confirm and adjust your memory setting in the BIOS accordingly
    for better system stability.
    Example: Kingston HyperX DDR2-800 PC-6400 operates at 2.0V, 4-4-4-12.
    For more information about specification of high performance memory
    modules, please check with your Memory Manufactures for more details.
  • Nicu Jenunchi
    What memory module do you use?
    Can you change RAM settings (like DRAM clock) in the bios?
    You should just try.
    Another possibility is to try:
    reduce at all video settings in game (to the lowest possible level),
    than increase one-by-one and check the game
  • Nicu Jenunchi
    Tell me please exactly the model of your nvidia video card?
  • Nicu Jenunchi
    Read here
    http://www.adriansrojakpot.com/Speed_Dem...
    and try. Do not affraid, the dangerous settings will not be possble to make.
    And, what can i say about your mainboard - i personally don't like this chipset (subjectiv) and i hate mainboards with onboard video.
4 Suggested Answers
SOURCE: MOBO intel DG31PR - OCZ 4gb dual channel - AUDIO problem.
i had had the same problem,
simply you can solve it by updating your bios setting :
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2839&DwnldID=17084&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
install it , note you may need install the latest audio driver too:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2839&DwnldID=16998&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
good luck>>>
Posted on Jan 01, 2009
ziraffa
  • 827 Answers
SOURCE: pci memory controller
This is to do with the interface control between the motherboard and your graphics card. For instance, if you have a nVidia graphis card, the latest driver for your particular card will contain the PCI memory controller information for you operating system.
So get the latest driver for your graphics card and see if the yellow exclamation mark disappears..
Hope this helps
Chris (ziraffa)
Posted on Jan 18, 2009
SOURCE: Audio device is not working
I have been working on this for months and finally got everything including front audio panel going. First Download the latest realtek audio drivers available  from intel's website or go here and download #3 http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows%2A+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21. Next goto control panel and add/remove programs then look for realtek audio drivers that have been previously installed. Remove program if one is found. Then go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+" in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at chadmon10@hotmail.com
Posted on Feb 16, 2009
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
Ram ok ,power sap ok ,lcd ok, cpu fan raning but no dimply, msi 7312 ver 1.0 plzz help
Hi, you can download a manual and drivers here:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Manual
You can add a AGP screen card if the onboard graphics
does not work.
Check the connections for the screen cable.
Try even with another monitor.
Sep 08, 2011 | MSI K9MM-V Motherboard
MSI -K9MMV VGA DRIVER FOR WINDOW 7 SEND ME....PLEASE
Here is only drivers for xp:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver&os=XP%2032
But you can add a AGP graphic card that supports windows 7.
The AGP card is a discontinued product
you can try to find a used one
Good luck
Jul 19, 2011 | MSI K9MM-V Motherboard
MS-7312 Vga Driver setup for vista
Hello here is no vga drivers for vista look here:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver&os=All
But you can buy a graphic card compatible with your windows system.
One AGP 8x slot
Good luck
Oct 18, 2010 | MSI K9MM-V Motherboard
Is it possible to upgrade NVIDIA geforce 6100 with higher one in motherboard
agp cards only work on agp and pci on pci can not put epci cards on board ok jim
Mar 10, 2010 | MSI K9MM-V Motherboard
Need graphics card supporting the msi k9mm-v motherboard
here are the cards that you might be interested in.
Series 1
Series 2
Any one of these cards are the best AGP card you're gonna get. Only thing is, make sure your PSU is up to par. You will need at least a 450 watt psu.
It will be effective if you have 2gb RAM and Dual core processor.
Nov 28, 2009 | MSI K9MM-V Motherboard
RAM issue
In total it supports 2GB Ram. More than 2 gb is not supported my MSI k9MM series boards
Jun 25, 2009 | MSI K9MM-V Motherboard
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
PNY geforce 6600 ddr 256mb agp/ with Asrock k7s41 motherboard When i install PNY geforce 6600, sis 741 chip on mobo seem to be still running. have changed to AGP from PCI in bios, card will...
PSU 250W usually isn`t good with GF6600 (like and high) videocards. Strongly recommended 350W and high for this configuration (and "350W" - not only numbers in model - for really QUALITY PSUs).
Sep 25, 2007 | Asrock K7S41 Motherboard
Intel Motherboard Logo
109 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
