Question about Acer Aspire 3680 Laptop
Thanks for the assistance
Hi josh, first of all thanks for offering to walk me through the process of disabling the lcd screen via bios i would greatly appreciate it if you could walk me through the process as i am a bit technically uneducated
  • madmaca Jan 27, 2008
    cash is kinda tight at the moment so i can not afford to sing up for live chat at the moment :( but thanks for all your healp it is greatly appreciated
    i got it sorted thanks very much for pointing mein the right direction :D
  • 105 Answers
You will need to sign up for the chat program.
http://www.fixya.com/PostQuestion.aspx?prdid=0&ctgid=0&ref=live
Posted on Jan 27, 2008
  • jp
    jp Jan 28, 2008
    oh good! i am glad you got it fixed!
Cmv 933a (chimei lcd monitor)
Do you see a BIOS screen before the PC loads Windows?
Power off and complete a cold boot from switch. If you still can't see the BIOS screen then check that you have plugged the cable into the right socket. Some PC's have on-board outputs and when a High End Graphic card is installed these are disabled by default. Look at the pins in the VGA plug for bent pins.
If you see the BIOS and then lose screen then the refesh rate or screen resolution is incorrect. We Windows Logo shows press the F8 key at the top of the keyboard to enter safe mode and then change the screen settings down to say 800x600 or 1024x768 to start with. Also make sure that the screen refresh is in 60 hz to start with at these resolutions.
Jan 11, 2014 | Computers & Internet
I press function key & the wireless capabillity still dnt turn on is there another way 2 turn it on? its a ms6837d
Most consumer laptops have a hardware wifi on/off switch located on the sides of the laptop or toward the top row or even near the trackpad.
Also, on some laptops and most netbooks, the Fn key has alternate uses, however, it most keyed in with other keys in order to make the shortcut execute the command. In this case, Fn might not work without also holding the "Shift" or "Ctrl" key + the F-key that corresponds to the enabling/disabling of wifi.
Lastly, you might also want to look into the BIOS screen (when booting the laptop) most portable devices offer a low-level disable from that menu so that even when enabling via the Fn-keys or directly from the Windows/OSX/Linux OS, it will not turn on and stay disabled until changed via the BIOS menu.
Aug 10, 2010 | Computers & Internet
Our computer is telling us we need to update the BIOS computer shuts itself off
All BIOS components are serviceable via a firmware upgrade that is known as "flashing" this process is called "updating the BIOS". The process itself is fragile since any power fluctuation during a flash may irrevocably corrupt a BIOS' firmware. Great care will need to be taken in order to safely accomplish this.
This guide will help you flash your BIOS by taking precautions and walking you through each step. Not all computers will have the same BIOS manufacturer, let alone the same process, but many have similar steps and precautions.
Guide: http://www.wikihow.com/Update-Your-Computer%27s-BIOS
Also check with your motherboard manufacturers website for specific BIOS updates and updating instructions. mpawlak908
Oct 18, 2009 | Intel Computers & Internet
Hi BIOS password fogoten
you will have to contact Toshiba. desktop units are fairly easy to reset bios passwords. laptops are very difficult if not impossible to do this with. if you are the original owner of the laptop they will assist you with walking through the reset process. if this is out of warranty they will charge you. good luck !
ruben
Jul 13, 2009 | Toshiba Satellite Pro L300 Notebook
BIOS password set and I don't know what it is
ok when i get work tomorrow iwill give you
May 17, 2009 | Acer Computers & Internet
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Bios password acer aspire 9410 Notebook
hi im josh in cebu phils. if the you forgot the password then you can delete or changes it. you go to the bios utility setup then go to security settings then disable or change new password.then save the changes then reboot your pc. bang! problems solved.good luck
Feb 23, 2009 | Acer Aspire 9410-4317 Notebook
Sound problem
hi im josh in cebu phils.may i help you? friend if the sound immediately whle you are working. try to go to bios setup then audio settings if disabled. or to your sound button near the clock.try to check if it is not checked in mute. then you can also check your audio connections at the back of the pc be sure the connections are stable.lastly try to install your audio driver once again coz maybe the software is corrupting thats why it disabled. good luck.pls.vote me so that i wl knw if i help you.thanks
Feb 22, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
Bios cheksum error
hi im josh in cebu phils. may i helped you? Friend you need to replace your cmos battery because The most common cause of a checksum error during the startup process is due to a faulty battery which is not providing sufficient power to the motherboard when the computer is off. However, motherboard malfunctions and viruses can also contribute to checksum errors. good luck.
Feb 21, 2009 | ASUS VIA Apollo Pro Plus Chipset P2V-B...
Acer Aspire 3680 Laptop Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
