Question about Samsung Digimax D53 Digital Camera
Problem with startup
My Samsung Digimax D53 issues several fast beeps then immediately shuts down again on start-up. I have tried new Duracell AA batteries and fully charged rechargeable NiMH AA batteries. The strange part is that sometimes the camera will start up and operate fine for a short period.
Thanks in advance for your assistance
  • Anonymous Feb 23, 2008
    Same problem. I have changed the batteries but that doesn't help. My camera just shuts off as soon as I turn it on.
My samsung d53 issue is .when u turn it on it beeps 3 times and shuts off. thats all it does.... cant take a picture its like the batteries are low.But they are not. what is wrong. like new! jimmy
Posted on Feb 23, 2008
Now something that will actually help you.
1) the reason this is most likely happening is that the lens is blocked.
how i fixed this was (I'm not kidding) I hit mine against a card board box. and that dislodged the lens, now it works. you can also just try taking it apart and cleaning it. that gave me an electric shock so be careful.
hope I helped you.
PS "you might need an idiot to do this for you. no kidding."
Posted on Mar 08, 2008
Does it turn off immediately after the it beeped? Are you using a rechargeable battery? Have you tried fully charging the it? You should also try fresh set of batteries and see if it will resolve your problem.
Oct 20, 2011 | Samsung Digimax D53 Digital Camera
Samsung digimax s700 gives 3 beeps and turns off
The Samsung digimax takes standard AA batteries (but you already new that). The beeps sound like a flat battery warning.
A lot of reviews of this camera note its very high drain on batteries. Are you using good quality AA batteries (for example Duracell M3 or Energizer lithiums)?
If you are trying to run it with "very inexpensive" alkalines (or worse yet - common zincs), then you may proceed directly to flat battery warning, as they cannot provide enough sustained current to run it.
Feb 28, 2010 | Samsung Digimax S700 Digital Camera
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
Did you try this?
Well I have had similar problems with this camera model. I tried several types of batteries and changed the battery type settings from the menue too... the problem changed a little bit but it did not solve the issue. I send the camera to Samsung service but got it back with "no fault found".
as I am working in this business I could not believe that a camera like this is not able to make less than 10 pictures with one set of batteries....I gave not up.
here is what I found:
when you open the camera by releasing the little screws from the buddy you will find several connector clips holding flatcables. this clips have not been closed correctly. just close them carefully!!! with a forceps and you will have a nice camera! this work can't be done in take your time.
Oct 30, 2008 | Samsung Digimax D53 Digital Camera
The beeping is as a result of low power. I found several articles on-line about this, and you are not alone. The best solution I saw was to use NiMH Rechargable batteries. They say it takes the life from 30 shots, to 30 days worth of shots if you get the correct rechargable AA Batteries.
If it is not power, then I am sorry, but I am of no help.
Many people complain about the life of batteries, and this beeping though, best to try it, and see.
Apr 23, 2008 | Samsung Digimax D53 Digital Camera
Camera Won't Turn On
if your having battery problems then i suggest recharables...i got energizer AA rechargeable set and it works perfectly for me...hope this helps :D
Mar 25, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 beeps and shuts off
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on and everything was working again ! Whew ! Problem Solved :D Good luck!!
Mar 15, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 camera
lenses are jammed. send it to a service technician. sorry.
Oct 03, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
134 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
