Question about Technics SA-DX930 Receiver
Surround sound is not working
I have an SA-DX930 5.1 receiver. It is only working in the stereo mode. The surround sound is not working. It doesn't show any errors.
  • 1 more comment
  • Anonymous Mar 01, 2008
    stereo working in stereo mode only......... no surround sound............cd posting live music but no sound in either speaker....................
  • wrotethebook Mar 02, 2008
    similar to last person only have stereo capabilities...............surround sound isnt functioning properly and the volume is up much higher for much lower sound...........................
  • dinosanta Jan 31, 2009
    I have the same problem no surround sound, just stereo and the volume has to be turned up a lot to get some sound in stereo.
6ya staff
SOURCE:
Anonymous
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
Anonymous
  • 3 Answers
SOURCE: technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Posted on Jul 12, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Technics SA-DX950 surround sound problems
The most likely culprit here is the output protection relay. The contacts are a little corroded and the higher volume "jumps the gap" temporarily "cleaning" the contacts. The relay should be changed. I don't have the manual with me, but the following relays are in the unit. One of them is the speaker relay:
Part # Cost
RSY0054-C $12.63
RSY0040M-0 $ 5.89
K6B2AHA00014 $ 8.14
Dan
Posted on Nov 12, 2008
Anonymous
SOURCE: Digital surround mode not putting out bass-RX-6022V
On the unit, just left of the volume control there a "adjust setting", cycle through the modes until you SUBWOOFFER and then press CONTROL UP or DOWN to make it say YES. I have no idea how it switched to NO. Probably with my remote, but some time did pass and I'm happy I got my Bass back. Quantum of Solace sounds great.
Posted on Nov 30, 2008
CLARKPINK55
kirk
  • 71 Answers
SOURCE: the surround sytem
bad amp this riddled with faults bad design dont waste your money on this dump it i repaired loads of these this model is bad news and un reliable
Posted on Dec 08, 2008
Can't get surround sound sound through tv mode, have sound only when cable box mode is on. I've tried hooking optical cable straight from receiver to tv and I've also tried AV jacks. Not sure.
The audio signal that your tv is producing is a stereo signal only - not surround. You should be able to manually put your receiver into a surround mode when using the tv input and get surround sound that way.
Sep 23, 2016 | Audio Players & Recorders
No surround sound in TV mode
Surround sound will only work if the source signal is coded as surround. Many older TV broadcast programs are stereo only. If your surround sound is working with a DVD or blu-ray then the broadcast source is the problem
Dec 02, 2013 | Denon AVR-1506 Receiver
Whent I connet my android to my samsung HTC55 using the aux 2, just one speaker work, that is correct? is there a way to connect my android and all my speakers work
Your Android phone can only output in mono or stereo, but it does not have a surround sound decoder, so it cannot output natively to a 5.1 surround sound system. However, your HTC550 has a Surround Sound Mode called Dolby Pro Logic II, which will simulate 5.1 sound from any stereo input. Try activating Dolby Pro Logic II mode on your receiver to get surround sound on your Android phone.
Apr 28, 2011 | Samsung HTC550 Theater System
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
No surround Technics SA-AX530
There is likely separate gain controls for your surround channels on this receiver and they are probably set at -10dB. Enter the setup menu labled "level" and increase the amount for each channel equally.
Jun 18, 2009 | Technics SA-AX530 Receiver
My Panassonic SA-XR50 Receiver is not producing surround sound from either of the Optical imputs from the TV or DVDR Both outputs are stereo L and R + subwoofer How do I rectify this What settings should I...
First enable the surround sound mode for the selected input and verify that the media playing is recorded in some mode of surround sound.
You can however, acheive surround sound from 2 channel sources with dolby prologic or prologicII sound processing, or other proprietary modes that your receiver might have from the manufacturer.
Jun 12, 2009 | Panasonic SA-XR50 Receiver
SA-HT 900 only plays music in flat surround mode no others work
I plugged some headphones in and then unplugged em and now my stereo only has abass sound . The stereo speakers seem to be broken . Have you ever heard of this problem before ?
Jan 29, 2009 | Panasonic Home Theater System System
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Technics SA-DX930 Receiver Logo
112 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
