Question about Sony KV-27FS13 27" TV
Buttons on top of TV don't work
My Sony KV-27fs13 is stuck on Video 3. The power button is the only button that works. The other buttons on the top of the TV don't respond when pressed. I suspect that one of the buttons is stuck in the on position. I have already attempted to reset the TV by unplugging it and waiting a few minutes to plug it back in. This had no effect.
  • mbutcher Jan 29, 2008
    The TV does not respond to the remote. The reason I think a button is stuck has to do with when I push the menu button on the front of the TV beneath the screen. As soon as the menu button is pressed it immediately begins scrolling down through all the different choices even though I have not pressed any other buttons. The menu button and the power button are the only buttons that respond to being pressed.
  • mbutcher Apr 12, 2008
    I had to have the tv serviced. It was a $130 repair and they had a difficult time finding replacement parts for this tv. It now works great.
Keypad switch assembly is most likely defective. This type of defect is common from cleaning the set with liquid cleaners and some leaks through. There may also be some damage to the some other components because of the mismatched load of the keypad circuits.
The set will have to be properly serviced to fix this fault. The cost will not be inexpensive to fix this.
Jerry G.
Posted on Apr 11, 2008
  • 2,336 Answers
Try to press them a bit harder, sometimes they become oxidize due to non use. If there was one that is stuck, you will not get any of them to work even the power button.
Try using the remote control.
Good Luck.
Posted on Jan 28, 2008
MY WEGA SONY KV-27FS13 TV - HAS SOUND THROUGH CABLE BOX BUT NO PICTURE. I DONT KNOW WHAT CHANNEL TO SET IT ON- AND DO I PUT IN ON DIGITAL OR ANALOG?
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Jul 23, 2011 | Sony KV-27FS13 27" TV
Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Oct 27, 2008 | Televison & Video
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
My sony kv-27fs13 has a problem .. the standby light flash 4 times . What is it ?
Hi there
In sony tv`s the 4 blink code(sony error codes)usually indicates a vertical deflection problem.
Your vertical output i.c and/or related components are probably faulty and need to be replaced.
If you feel that your up to repairing it let me know and i`ll see what i can do to help.
Merry Christmas
Dec 24, 2009 | Sony KV-27FS13 27" TV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS13 27" TV Horizontal lines in the form of brigter to darker values of the picture, half screen size, moving from bottom to top of screen. I've been able to give the TV a lite tap on the top...
this sounds like 60hz or 120hz a/c ripple distortion. if taping tv corrects temporarily, ther must be poor solder on main a/c ripple filter. very large usually blue capacitor near power cord input on pcb. do not short positve and negative legs together as you could be shocked(even after tv is unplugged) and also cause more damage to tv. these filters can store electrical charges for days, even if unplugged the whole time. careful! mch
Mar 08, 2009 | Sony KV-27FS13 27" TV
Pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
Dec 05, 2007 | Sony KV-32S26 32" TV
Green circle on the screen when I turn off TV
there is something really something wrong with your tv.try to reheat the main board.
Oct 30, 2007 | Sony KV-27FS13 27" TV
No picture and a "whistle"
If your friend is being honest, and why shouldnt he, and the set was knocked over, I'll bet there is now a small crack in the main board. Cracks in boards due to dropping or "knocking over" usually occur next to the flyback transformer or tuner. Cracks in boards are very easy to fix so if you do not have experience working inside TV's then allow a qualified tech to handle it for you.
Sep 01, 2007 | Sony KV-27FS13 27" TV
Sony Trinitron KV-27FS13
set in shut down. Hasve power supply problem. Need a TECH.
Sep 03, 2006 | Sony KV-27FS13 27" TV
Sony KV-27FS13 27" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
