Question about GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
Rave-mp 128 mp player
I accidentally deleted the software files that run my rave mp128 player. they are the autorun folder and the fm folder. And I can't remember what other ones were necessary to run it. Do you know where to find them? I looked on the install cd but could see any files there. Thank You for any help you can give me. Daniel
  • ticocamin Feb 01, 2009
    is black an freez
  • GoVideo Master
  • 5,390 Answers
Have you tried using the install CD to re-install the player?
Or you can go in windows and under folder options, click show hidden files and folders. And hide operating files.
This will show all the files on the CD.
Remember to restore the settings to normal after you have done.
Posted on Nov 24, 2017
3 Suggested Answers
SOURCE: rave mp mp3 player ---- frozen
It occasionally happens on mine. I just basically have to hook it up to the PC and reload the firmware. (Tnough it seems the company is no longer in business, you might be able to find the firmware update file out on the net somewhere.) Seems to freeze up more if I have the SD memory card in there. Had better luck with some types of SD cards than others (faster speed cards seem to cause me less probs.)
Posted on Aug 08, 2007
SOURCE: Lost software on Rave-MP AMP512 MP3 Player!
Here is the firmware upgrading tool for Rave-MP AMP and ILO256 MP3 Players:
http://www.filefactory.com/file/d6cbe0/n/Rave-MP-Install_exe
Posted on Oct 18, 2008
Access is denied
Hi
Possible reason is
that your pendrive Contains
An autorun.inf file pointing to a *.exe file(possiblly a virus)
So either you run a scan with good antivirus
or
You can delete the file manually by
> Goto>> Run>>Type the drive letter of your pendrive and follow a full colon(Eg: "C:")
then just enter
now if you cant see the autorun.inf file
you go to folder options to change the view
that is (go to tab view )
1. tick "show hidden files and folders "
2. Untick " Hide operating system files"
Apply it
now you will see the autorun.inf file just delete it
It will solve your problem
Mar 05, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Delete autorun.inf and that reappears. there also a folder called recycler that also reappears....
the folder named recycler is harmless..but the file autorun.inf is parasite..we can remove that using a software named "autorun eater"
and it is available free
http://www.softpedia.com/progDownload/Autorun-Eater-Download-85585.html
Jan 02, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How do I delete songs existing on Rave.mp ?
Once you can connect the device to your computer, it should popup like a use device that you can delete the songs or file you want.
Aug 17, 2009 | GoVideo Rave-MP AMP128 (128 MB) MP3 Player
What are all the folders in the Coby MP705-4G
MUSIC
PICTURES
Playlist
TXT
VIDEO
That's the same case the names on mine have.
In the root, there's 2 files....
MTP.BIN
WMPInfo.xml
That's it.
Mar 04, 2009 | Coby MP-705 Digital Media Player
No music file showying on MP-BT1
Just check they are not located inside a folder on your MP-BT1. If so, drag files out of their folders and then delete the folders and MP-BT1 will then recognise them!
Jan 07, 2009 | Tascam MP-BT1 MP3 Player
Problem in viewing the folder MICIN.DIR in my player but the files are visible in PC
I have mp3 digital audio player emprex (128 mb). Now i have some problem. When i recorded music from computer into my mp3 and after i want to listen it , my mp3 player didin't play and it didin't show my recorded music.But when i connect to my computer, i can see my recorded files mp 3 music. What should i do now?
May 04, 2008 | Audio Players & Recorders
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
SD Card
Mine works with 2GB card... AFAIK, that's the max, although I haven't tried a 4GB card.
I found updated firmware at:
http://uiss.max.io/
*update*  site has not been updated and download links not working... useful info there nonetheless... I will put the file(s) on my site:
http://french.moren.ca/rave-mp/Rave-MP-Install.zip
http://french.moren.ca/rave-mp/iLO256Manual.pdf
expect them up there by Oct. 20/07...
the ILO player referred to there is electronically identical, if not physical and the update works with all the Rave MP AMP series. I had a hard time finding this but it was worth the effort.
works great :-)
Sep 05, 2007 | GoVideo Rave-MP AMP512 MP3 Player
GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player Logo
43 people viewed this question
Top GoVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a GoVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
