Question about Mitsubishi VS-45605 50" Rear Projection Television
CS-27403 vertical rolling. no vertical button or knob
    Genius:
  • 1,694 Answers
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Posted on Jan 27, 2008
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
Picture roll up and down
Standard CRT televisions have a vertical roll adjustment,usually on the back at the bottom.
It may look like a white finger-knob (about the size of a pencil eraser) with a small screwdriver slot in the end...or it may be a roll-wheel...either way, it will be labeled "vertical" (or just "vert").
Make slow adjustment to the vertical until the roll stops.
*Use a solid signal for the adjustment, like DVD, VCR or cable...a weak signal can cause a bit of roll, too.
Apr 11, 2010 | Sony Televison & Video
I cannot find vertical hold
The sync is automatic. There are no knobs to turn. If the picture is rolling, look first to the source connection and make sure your tv has a solid vertical sync connection. If you are using the RF input then the issue could be within your small signal board also known as the SSB. Good luck.
Mar 23, 2009 | Televison & Video
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Rolling video screen
The TV Vertical rool has been adjusted. Look for that control on one of the knobs, if there are any. If you can't find it, it is probably internal and near the opening.
Jun 06, 2008 | Microsoft Xbox Console
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Rolling Screen on GPX D1816
Press the n/p button on the original remote control that came with the unit. It's located between the stop and rewind buttons.
Dec 27, 2007 | GPX D1816 DVD Player
Vertical rolling of picture
If the picture rolls while both on cable as well as when you playback a tape or DVD, it could be caused by a bad filter capacitor in the power supply or vertical deflection circuits. If it only rolls while trying to view a picture from a cable/satellite box, then that component is likely at fault.
Aug 20, 2007 | Hitachi 60EX01B 60" Rear Projection...
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
Mitsubishi VS-45605 50" Rear Projection Television Logo
216 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
