Question about Dryers
Dryer not heating up
I have a hotpoint VTD20 dryer which is tumbling but not heat is being produced. I have tried de-fluffing it as much as possible, but can't get past the filter to clean it out thoroughly. Is there a reset button on it or something? Where do I open it up from to get to the problem?
    President:
  • 1,314 Answers
The first thing to do is check the power at the outlet just because it runs doesn't mean your getting 220 at the out let next take off the cord cover check there to see if you have 220 going into the drier if all that's ok then we will open up the drier at the cord check for 220 to hot to hot then check for 110 from L1 to neutral then for 110 from L2 to neutral and reply we will go from there
Posted on Jan 27, 2008
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hi i have a hotpoint tcm condenser dryer and dosnt seem to dry my clothes anymore?
You need to clean all the fluff out of the dryer, the heat exchanger gets fluffed up, the fan gets fluffed up.I am assuming that the dryer is getting hot?
Mar 05, 2011 | Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Hotpoint aquarius tdc32s not heating up
Common faults -
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius vtd20 not heating
sounds like the heating element is bad or the heater box fuse and thermostat one of the 2 is bad,if you have a meter you can check all 3 on the ohms setting,let me know-mike
Feb 15, 2009 | Dryers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fjj
Feb 15, 2009 | Maytag SDG4606A Gas Dryer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
182 people viewed this question
Top Dryers Experts
