Question about GE Profile JTP18 Electric Single Oven
Loc ref code
Hey doc see if you can help with this thanks 17 http://www.fixya.com/support/t371622-locref
  • kabuta87 Mar 26, 2008
    I have same problem loc rEF with my slide in GE JCS968BKBB,replaced touch pad no help.Tried to reset by pressing 90 for more than3 sec but no success.Can somebody help me to resolve the problem.
    thanks.
Just solved the Loc ref problem by going to Ge customer net. By pushing the 6 and 8 numbers at the same time on the contriol board, will reset the machine. worked for me, hope it does the same for you.
Posted on Oct 15, 2008
  • 1 more comment
  • On a mission Oct 30, 2011
    This totally worked! This is what I did: Press 6 and 8 together. It still displayed the locked door. I then hit the bake button and the dashes appeared to input the numbers for baking and the locked door display was gone! Saved me hundreds of dollars! Excellent advice.
  • rdavis152
    rdavis152 Dec 08, 2012
    Wow! Thank-you Thank-you Thank-you. I read all the manuals the range came with and nothing about hitting those buttons. It totally worked! Thank-you!
  • Anonymous Jul 18, 2017
    Thanks!!! Worked for me too. Nice touch pad now that it works!
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
What does F 03 on the display mean (my oven is not working)
Most Whirlpool ovens and F3 code is a failed temp sensor.
See this link:
http://www.applianceaid.com/oven_temp_sensors_help.html
and this one:
http://www.repairclinic.com/Fault-Codes
An oven too HOT indication is also F3 but the cause is still a failed temp sensor.
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Whirlpool Ovens
What does error code Loc mean?
Hello & Welcome to FixYa
Press & Hold the START PAD for 20 seconds to turn off LOC error. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
I need an User Manual for sanyo microware oven model: EM-G4775 Thanks
Hi and welcome to FixYa, I am Kelly.
You can download your manual here: (2.08 mb / 17 pages)
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-G4775.pdf Rt click link then "save as" or you can open it in your browser and then save it.
I was able to successfully download the manual using the above link.
Kelly
Apr 05, 2011 | Ovens
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
1,628 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
