Acer TRAVELMATE 2300, 2310, 2410, 4000, 4052LCi, 4500 SERIES KEYBOARD - 99.N7082.01D PC Notebook
Problem for Acer TRAVELMATE 2300, 2310, 2410, 4000, 4052LCi, 4500...
Problem in using webcam of the travelmate 3260
By 00shar00 on Jan 27, 2008
i have acer laptop travelmate 3260 and when me try to using the builtin cam it says sometime not have device or using by the another application but in case i put the driver before that time it showing there in device manager that got driver accurately but after restarting i got so problem
so plzzzz tell me is there is any solution about that problem
Comments:
Jan 28, 2008
- ty freind for ur reply but u know me try all that method before. even in some laptop cam works with the fn+f10 or +f11 me try everything go in the main global site of the acer search for driver for same model even download the driver for the same service tag number but when me start cam its says not working and says another program using
me format again laptop and try that without any program in that but uffffffffffffffffffff still having same problem
Same Problem
Sep 07, 2008
-   mon webcam ne fonctionne pas sur vista malgré que l'instalation et terminer avec succé -   Guest
Aug 10, 2008
-   Yeah I encounter exactly what they experience. All the info about web cam are the same. So please try to do something because i try to re pormat my laptop just to check if my cam will work but unfortunately cant fix it. please help us to figure this out.thanks. My product is travelmate 3260 ACER-   dj_ice
Jun 25, 2008
-   i have same thing:((-   Guest
Jun 06, 2008
-   camera is in use by another application-   smallseal
Feb 18, 2008
-   cam is using by another application-   basirathkhan
Best Solution
posted on Feb 02, 2008
Helpful)
ComputerDave
Rank: Guru  Acer Expert
Rating: 88%, 445 votes
There is a utility bar that you can install that lets you change the default application folder:
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Was this helpful?
Yes
No
Solution #2
posted on Jan 27, 2008
Somewhat Helpful)
nylo
Rank: Wiz
Rating: 84%, 72 votes
HII 00shar00,
u can download the webcam driver from this link..plz install adobe flash player for this web page to open.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=6856235&CFTOKEN=76917716
PLEASE FOLLOW THIS LINK IF THE ABOVE MENTIONED DOESN'T WORK :www.acerpanam.com
CLICK ON DRIVERS AND DOWNLOADS
  1. select notebooks option under product line
  2. under product select acer travelmate 3260
  3. under download select the webcam drivers
there r many webcam driver available like
  1. bison crystal eye webcam driver ...and its application
  2. logitech crystal eye webcam driver ...and its application
  3. suyin crystal eye webcam driver ...and its application
please select the appropriate one and install
plz try this and do reply if it works
thank you
Comments:
Jan 27, 2008
- PLEASE NOTE: THE WEBCAM DRIVERS NAMES ARE WRONGLY MENTIONED BY ME ..
THE CORRECT ONE ARE
  1. bison ORBICAM driver ...and its application
  2. logitec ORBICAM driver ...and its application
  3. suyin ORBICAM driver ...and its application
Was this helpful?
Yes
No
Solution #3
posted on Nov 18, 2008
Not Rated)
aselsan
Rank: Apprentice
Rating: 0%, 0 votes
Hi to everybody !
Please help me to finde drivers acer travelmate 3260 / WEBCAM DRIVERS
I download all driver from acer ftp but only one driver -camera - didn`t extracted
I think that this driver -driver vebcam is damaged !
Where can I finde other vebcam driver
thanks
from Elsan
Was this helpful?
Yes
No
Solution #4
posted on Oct 13, 2008
Not Rated)
mehaq
Rank: Apprentice
Rating: 0%, 0 votes
I had similar problem, downloaded latest drivers from the acer website, in my case it was Logitec. Uninstalled previous Orbicam driver and application. Restarted computer, windows XP found the camera and asked for drivers therefore installed that using downloaded drivers. After restarted the camera started working. Then installed Orbicam application and now camera is working fine with me.
-mirza jed
Was this helpful?
Yes
No
Popular Solutions for Acer TRAVELMATE 2300, 2310,
Questions and Unsolved Problems for Acer TRAVELMATE 2300, 2310,
Do you recommend Acer TRAVELMATE 2300, 2310, 2410, 4000, 4052LCi, 4500 SERIES KEYBOARD - 99.N7082.01D PC Notebook?
Answer
Answer
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can... (More)
Answer
I want to unsrew the screen to fix a problem. When i try to close the screen cover certain nuts to... (More)
Answer
solution: Kaspersky Antivirus will remove "Autoit" worm/trojans.so download it from its... (More)
Answer
have absolutely no idea where to start Very new to computing . I have an Acer aspire 5735Z
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(646) 202-3935
Macbook LCD Screen Replacement $159 iPhone 3g...
NYCiPodDoctor 877-TUNEDOC (8863362)
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
